brake chamber leaking from rear when brakes applied
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Oct 15, 2017.
  1. AModelCat
    161,679
    I would confirm the lines are correct first and then go from there.
  3. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    im confused the lines came off of the parking bake chamber there are no ports on the service side. Once i know which line does what (easy) where do they go?
  4. AModelCat
    161,679
    Yes both ports will be on the park chamber. One port will be slightly closer to the service chamber though and it will be the one that receives air from the brake pedal. The other port will get air supplied to it when you push in the park brake valve on the dash.
    TowHaul Thanks this.
  5. TowHaul
    416
    79
    Mar 7, 2016
    perfect!! Thanks will report back tomorrow
  6. TowHaul
    416
    79
    Mar 7, 2016
    is the leaking air symptomatic of crossed lines?
  7. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Did you read the mounting hardware instructions? I know it looks easy on paper, but these brakes must pass a DOT inspection.
    Bean Jr. Thanks this.
  8. TowHaul
    416
    79
    Mar 7, 2016
    yes, no explination for understanding dynamics of how leak is occuring
  9. DustyRoad
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    baha and TowHaul Thank this.
  10. DustyRoad
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
  11. TowHaul
    416
    79
    Mar 7, 2016
    so make sure park line goes to port furtherst from service chamber? Service air line to port closest to seevice chamber? Going to attack this mini project in few hours. Thanks for your help, seriously you guys rock.
