brake chamber leaking from rear when brakes applied
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Oct 15, 2017.
  1. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    lines appear correct , i reset the rubber gasket. Now what
  3. TowHaul
    416
    79
    Mar 7, 2016
    both parking lines connect in a common unison valve and both go to same ports on chamber
  4. TowHaul
    416
    79
    Mar 7, 2016
    rear chamber exhausting air when servicr brakes applied
  5. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Any air leak at the chamber is a failed chamber or failed service brake diaphragm seal. Crossed lines do not leak, just reversed brake behavior. If you are leaking air out the rear of the chamber you just installed, then the diaphragm, (rubber gasket) must have a split or hole in it somewhere. Getting the chamber, diaphragm and clamp all lined up is tricky. This is one of those jobs you need three hands for! It is easy to have everything lined up, then you look down to grab a wrench, and everything slides out of place when you aren't looking. So it is easy to get it mis-aligned and then leak afterwards.
    TowHaul and DustyRoad Thank this.
  6. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    My technical experience suggest replacing the diaphram which is not in new condition.
    TowHaul Thanks this.
  7. TowHaul
    416
    79
    Mar 7, 2016
    i took the new chamber apart and examined the diaphragm which appeared to be wrinkled and improperly inserted. reinserted and everything works great. So in conclusion it was the rubber diaphragm which was incorrectly installed and leaking.
    Heavyd and DustyRoad Thank this.
  8. TowHaul
    416
    79
    Mar 7, 2016
    You and DustyRoad property diagnosed the problem. Thanks to everyone for your help. Brakes work great now.
  9. brysol01
    brysol01 Medium Load Member
    317
    454
    Nov 2, 2009
    last truck I got was from Mankato Freightliner, they replaced the front part of the chambers, same thing,
    in different shop the next day, said they wern"t lined up right before tighting down the ring
  10. DustyRoad
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
  11. MM71
    MM71 Heavy Load Member
    760
    991
    Jun 28, 2008
    AZ
    adjust your brakes if you havent already .... over extending the diaphragm can tear or unseat it if your brakes are very worn and your sack adjusters are set very loose.
