Brake chamber pushrod
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Xyrex, Apr 23, 2023.
  1. Xyrex
    Xyrex Bobtail Member
    15
    6
    Nov 27, 2020
    Hello I'm in a weird situation where I have a zip tie on the pushrods of the brake chambers to measure stroke. On only one chamber when I check the stroke with service brake application I have 2.0 inch stroke but when I apply parking brake it only shows 0.5 inch. Already verified parking spring not broken. Any ideas what could be going on?
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    You don't need zip ties to measure stoke. Your eyeballs work just fine.
    Brakes released just look at the brakes. Gaps between shoes and drums. Adjust them.
    Closed gaps won't have much stroke compared to open gaps. Brakes work better with a half inch gap over 2 inch gap.
    You guys sure make things difficult when all you gotta do is look at the gaps.
    Big Road Skateboard and Stringb8n Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    I would say you have something going on inside the chamber you cannot see.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    With service brakes you can apply up to the full air pressure in the system (105-140 psi).
    With the spring (parking) brakes applied, the spring only gives about 45-60 psi equivalent pressure. So you will see less pushrod travel as there is less pressure being applied.
    Although 1-1/2” difference does seem like a lot. So either the spring in the chamber is old and weak or could be broken in a way that it’s barely making contact.
    So it’s probably worth changing out that brake chamber.
  6. Big Road Skateboard
    7,115
    40,383
    May 2, 2021
    There's just not much there to go wrong. As long as you have no air bleeding into thr supply side (would assume not since only affecting one), and since it's working properly with service brakes, just change it.
    beastr123 and Rideandrepair Thank this.
  7. SmallPackage
    5,806
    18,603
    Dec 20, 2019
    Marion Texas
    Are the slack adjusters both mounted on the s-cams at the same angle and are at same angle when brakes are released? If so then the longer stroke on the one side is caused by slack adjuster bad and will not stay in adjustment, broken or worn spring in chamber, or a long stroke chamber was installed on that side and the other side has a short/standard stroke can. I have seen that mismatch happen when someone needs a can in a pinch and long stroke is all that is available. Same with trailers. Seen many get a standard when they need a long. That Causes weak brakes instead of overly tight brakes.
    Rideandrepair Thanks this.
  8. AModelCat
    164,846
    Spring is probably broken. Once in a blue moon they'll break in such a way that the slot for the caging bolt is still lined up with the access hole in the back. Give the chamber a few light smacks with a rubber hammer or your palm and you'll probably hear pieces of it rattling around in there.
  9. Rideandrepair
    17,566
    56,910
    Aug 8, 2015
    That’s what mine did. They were broke, but couldn’t tell. Still had tension. That’s why they always cut the spring in two places to disable old ones for safe disposal.
