Brake issues: driver side steer locking up, how to diagnose?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rookiedriver93, May 3, 2017.
  1. rookiedriver93
    rookiedriver93 Bobtail Member
    13
    7
    Mar 29, 2014
    Need advice as to what I should be trouble shooting. When loaded , if I have to get on the breaks really quick , for example red light, being cut off and such, the drivers side steer locks up. This has caused me to skid. Luckily it hasn't led to an accident. I find that it's usually only when loaded and on a quick and hard break situation. Any advice would be appreciated. KW T680 2016 . Thanks.
  3. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Brakes out of adjustment? First thing I would check plenty of YouTube videos on how to check.... Now if you have auto adjuster Wich you most likely do let a professional repair it...
    rookiedriver93 Thanks this.
  4. AModelCat
    158,338
    Check for a wheel seal leak. Oil on brake linings can cause it to grab hard sometimes.
    I have seen the brake chamber bracket twist on some trucks and cause some funky things to happen as well.
    Does it lock up and stay locked up? Being that it would have ABS it shouldn't stay locked.
    Road conditions? Is it possible that whenever it has happened there was water or loose gravel on the left side of the road?
    Also being that its a 2016, does it still have warranty?
    BoxCarKidd and OLDSKOOLERnWV Thank this.
  5. rookiedriver93
    13
    7
    Mar 29, 2014
    Yes on warranty. Dry , good paved road conditions. No loose dirt nor gravel. It wasn't the rumble strips either like I thought the first time it happened.
    Oxbow Thanks this.
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Have them pull both FT. drums, the one thats locking up on you is having to do all the work and may need to be relined like the other side thats not doing it share of the work because of wheel seal or you will not know till you can look at both sides?
  7. mitrucker
    mitrucker Road Train Member
    5,231
    9,235
    Dec 15, 2010
    Lapeer, MI
    I was having the same issue. Shop pulled both sides apart and found nothing wrong. Haven't needed to dynamite the brakes since. Not to sure what will happen if I do. Really don't want to find out either.
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Is it drumbrakes?Or disks?
  9. Ridgeline
    22,365
    115,986
    BS on checking it yourself, don't try to check a thing, call your company NOW and tell them you are having serious issues with the brakes on the truck, tell them it is locking up and if they complain, tell them if is not driving right to cover your butt, ask them to see if you can get it into the shop asap.
    It may be there is an issue within the drum causing it to hang and then grab like dry cams.
  10. Aradrox
    900
    622
    Jan 21, 2016
    All the things that have been suggested to check should be done daily part of pre trip
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    could be s cam bushings as well as the previously mentioned items
