Brake lights work but signals don’t
Discussion in 'Kenworth Forum' started by Bluemack, Mar 27, 2023.
  1. Bluemack
    Bluemack Bobtail Member
    6
    6
    Mar 24, 2023
    08 Kenworth. All lights work on truck and trailer except the signal lights. The trailer signal bulbs are fine as they are also used for the brakes. What to check?
  3. bad-luck
    bad-luck Road Train Member
    3,336
    6,154
    Nov 16, 2013
    Baltimore, Maryland
    Start with the flasher. They are cheap
  4. Coolbreezin
    Coolbreezin Medium Load Member
    403
    422
    Jun 11, 2016
    Florida
    When I drove for Marten my turn signals stopped working. Dispatch told me to get a replacement blinker relay. I did a little online research and found the location and number. I r&r the part and all was smooth sailing.
    Instead of searching through a forum, Google search it. That way you may find your answer in a forum you may not be registered to.
    Bean Jr. Thanks this.
  5. Bluemack
    6
    6
    Mar 24, 2023
    Flasher? What do you mean? Relay, switch, etc?
  6. Diesel Dave
    9,060
    28,199
    Jan 20, 2010
    Hesperia, Ca.
    Check the fuse first. If the fuse is ok, then it could be the flasher “relay” which is usually behind or under the dash. Looks like a small square box or round with 2 prongs(connectors) hooked to it. If it is the flasher relay, replace it with a heavy duty one.
  7. snowwy
    snowwy Road Train Member
    20,584
    13,303
    Jul 6, 2009
    Always check fuses first.
    The 07 I used to drive would pop them every time it rained. The problem was in the trailer.
  8. Bluemack
    6
    6
    Mar 24, 2023
    The problem is coming and going so I don’t think it’s a fuse
    snowwy Thanks this.
  9. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    You need to locate the flasher relay. It's the same think that makes the clicking sound when the blinker is on .
    It may just need to be pushed back in all the way or could be failing.
    If you can find it it's a easy as unplug and plug in a new one.
    Can be found at any parts store and even most truck stops
    Speedy356 Thanks this.
