Brake peddle return
Discussion in 'Volvo Forum' started by ejm, Mar 16, 2012.
  1. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    I have an 05 670. The brake peddle seems to have no return spring. If I try to use CC if I get it to set, I hit a bump and it knocks it out. I can hold the peddle up with my foot and all works fine. I can't even see where a return spring or ? should be. Anyone know the setup for this.
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I belive the spring is on the footvalve itself I'm not to keen on volvos but kw,pb,fl,and Mack all use that same foot valve and brake pedal mounts right to it so looks like your gonna have to replace the foot valve
    ejm Thanks this.
  4. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    I would fix it with a rubber strap and forget it..
    ejm Thanks this.
  5. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    Thanks for the quick response guys. This was a big help.
  6. Logear
    Logear Bobtail Member
    34
    9
    Jan 30, 2009
    Dade City, Fl
    There is a procedure for brake pedal height adjustment. The adjustment screw is at the top of the foot valve. it is an allen head screw with a 13mm locknut. Srew it in till you have .16 to .32 inch of free play.. That should fix it. Make sure your air pressure is up when you do it.. I had to do mine cause the guys in our shop were gonna go the
    spring/ bungee cord route.. There is a right way to do most things and a wrong way to do everything.
    KB3MMX and 25(2)+2 Thank this.
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yep, there is a spring on brake pedal, but with faulty spring brake lights are off becouse volvo use pressure switch
    KB3MMX Thanks this.
  8. Kanu
    Kanu Bobtail Member
    42
    5
    Jan 23, 2017
    Hi publo been looking for your help.when the trailer brakes have a slow release, is there any posibility the foot valvle is the problem?Everytime i stop lets say on traffic lifgts,my trailer is not releasing brakes like its supposed to and its driving me nuts
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    if you push red knob air fills trailer tanks. If trailer looses air you need some time to wait till truck compressor builds pressure in trailer tanks.
  10. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    I had same problem and new foot valve fixed it.
    KB3MMX Thanks this.
  11. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    I think you are miss understanding the question. He wasn't talking about that. What he was talking about is sometimes what you stop at a light or stop sign and you lift you foot off the BRAKE PEDAL. the trailer brakes are slow to release
    Kanu Thanks this.
