I have volvo 04 vn 64 w/ volvo engine 465. I haven't brake at trailer, if i press the brake pedal, brake doesn't work at trailer, if i press the red boton, it not send air for release the brake, but when air presure get 120 psi, it release trailer's brake. I replaced air valve under cab (where is hoses conected ) an nothing. Any idea ?
Thanks, walter
Brake problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by waltherz, Mar 23, 2014.
u have problems with tank protection valve.
Tank #3 (trailer brake tank) valve goes bad. from this tank trailer control valve and trailer red line are supplied.
normally valve opens at ~80 PSI -
ouh, check protection valves manyfold
Pablo, where is located that valve?
Thanks. -
on EU volvos it is on right frame rail, on US versions - usually on left frame rail, it is made of plastic, with quick connections
http://www.ebay.com/itm/Volvo-Tract...k-Conn-Fittings-for-VN-24426099-/111164954864
check also park brake knob valve too -
Thank you Pablo!!
btw, when this valve goes bad, red knob pops out, becouse really there is the spring inside and this spring pushes knob out so it is held with air pressure of park brake air tank.
it is not all. on some cummins engines air servos are used, and it may leak too. No air in system like u got, so check cummins turbo air servo piston for leak too -
thanks Pablo.I replaced the trailer protection valve, but problem still and red button only pop out with low pressure. If I press the red button isn't send air to unblock the trailer's brake. trailer's brake work with hand brake valve and not with pedal brake. I have Volvo engine.
really wierd. u have to check lines from valve to tanks.
What valve did u change? in cab ore air processing valve? -
trailer control valve test.
1)remove air pipe from port nr 43 on the trailer control valve.
2)release hand/park brake air should be coming out of the pipe you removed from port 43.
if not check pipes on port 41 and 42 if air comes out of either one of them put the pipe blowing air into port 43
for treddle / foot brake
1)remove pipes from port 41 and 42
2)tramp brake and air should come out of one or both these pipes.
remember #3 air tank should be the same tank supplying the hand brake and the trailer control valve with constant air.
