Brake problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Speedwagon98, Jul 26, 2016.
  1. Speedwagon98
    Speedwagon98 Bobtail Member
    38
    20
    Aug 23, 2015
    Northern Colorado
    I've been having trouble with the brakes on my trailer for a few months now. The shop has pretty much given up on fixing the issue at this point.
    This is an aluminum tanker trailer. Several months ago, if you hit the brakes fairly hard, the forward trailer axle would lock up and smoke the tires, when empty. Back in April, something happened though, and it started locking up the forward axle under normal braking. Wrote it up, shop looked at it, relaxed some parts. The first day it was fine, then starts doing it again. Wrote it up again. Same story.
    Eventually they send the trailer to Polar for repair. Get it back, works fine first day. Send it back to Polar. Get it back, almost everything has been replaced, and the problem has changed a bit. Now, under normal braking, the trailer squats, then starts bouncing. Often times I can feel the trailer let up on the brakes, then grab again hard, and repeat. If I apply the brakes a bit harder, the forward axle will lock.
    The shop doesn't know how to fix it. It does it on multiple trucks. What the hell is going on here? It feels like it is applying far too much braking power to the trailer.
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,364
    7,732
    Jul 11, 2012
    in the bush somewhere
    Had a similar issue on a couple of our Heil tanks. They were equipped with a Bendix ABS controller with roll stability. The dealer where we bought them suggested replacing the controller with a Wabco brand. They said they'd seen numerous issues with the Bendix controllers and that Bendix no longer would cover the repairs under warranty, not would they do anything to correct the problem.
    We did as they said, and the problem went away.
  4. Speedwagon98
    38
    20
    Aug 23, 2015
    Northern Colorado
    It is a Bendix controlled trailer
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Ugh.
    Find another trailer. IF you are able. Those trailers need to be stable.
    Im sorry I cannot offer you much more but all of my tanks never misbehaved the way you described. Locking is unacceptable unless it is in extremis no #### emergency and even then ABS should kick in and loosen it.
  6. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    "Often times I can feel the trailer let up on the brakes, then grab again hard, and repeat."
    That is the ABS working. Does it do this loaded and empty?
    Check the tandem weight on a split scale. If I run my trailer low with a light load it will let the ABS engage do to not enough load on the front axle.My DD has a lot of arch and factory ride height adjustment and first time I ran it low with little weight on the trailer the ABS kept actavting until I rasied the trailer and put more weight on the front axle.
    You suspension may be shifting weight off of one axle causing ABS to come on. Air ride or spring?
    If air ride look a bag height, should be the same, Spring ride may need rebushed.
  7. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    ABS works incredibly fast to keep the wheel rotating. Usually having activated it a few times in both a car and big truck (The car was a interesting situation bear with me) there is a great deal of buzzing going on as the system works to keep you turning until you get slow enough to input perhaps emergency steering to get out of a collision.
    I ran my olds 98 off once and the right front hit gravel I got on the brake to settle it down and three wheels was on pavement while the right front ABS activated. That was interesting Then the right rear hit the gravel and activated. Call it lesson in ABS work.
    Don't forget if everything is going against you and life is on the line you still have your red and yellow springs to pull. It will lock you down like that. *Snaps. ABS be ######.
  8. BigPerm
    BigPerm Medium Load Member
    Further to the ABS comments, a lot of control & relay valves LOOK the same, but can have different "cracking" pressures. Many mechanic's ( & parts folks) replace w/o checking, hence driveability problems. Replace a 15lb. valve with a 5lb. and you have a problem.
    ksCentury, BoxCarKidd and magoo68 Thank this.
  9. AModelCat
    157,227
    I remember back when they first started putting ABS on logging trailers. A relative bought a brand new tridem pole trailer and it only had ABS on the front 2 axles. He found that the rear axle was eating tires faster because it would lock up from time to time because it had no ABS. He ended up having the system retrofitted for ABS on all 3 axles.
  10. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    We had a rash of bendix abs valves go on fairly new trailers .. It was almost impossible to stop quickly from a slow speed without hopping the trailer wheels if empty .. Once you made 3 or 4 applications and got a bit of heat in the drums it was almost normal
  11. BigPerm
