Brake Saver File??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billandlori, Jan 23, 2011.
  1. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    Hey folks,
    I keep hearing about a "Brake Saver" file when getting an ECM tune done. What is this? Does it make the Jakes work better or something?
    Thanks for the edumication!!:biggrin_2558:
    Bill
    h50 Thanks this.
  3. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    A brakesaver file was written for a truck/engine that had a brakesaver on it...it will have a touch more timing and a touch more fuel...to overcome the parasitic loss of the brakesaver...so the truck will dyno the same as one without the brakesaver....so installing it on one without gives you more power due to the additional fuel and timing. Does nothing to help jakes or brakes.
    billandlori and 123456 Thank this.
  4. billandlori
    357
    107
    Sep 5, 2010
    Thanks you Sir!! That makes sense.
    Bill
  5. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Now you had better explain what a brakesaver is....I doubt many rookies know what they are.....
  6. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    LOL
    I was wondering how many would know what it was
  7. Gambi80
    Gambi80 Medium Load Member
    It's a higher speed limit isn't it? :biggrin_25525:
  8. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    The extra fuel is added to the brake saver files to compensate for the extra rotating mass of the actual brake saver unit.
  9. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    I had one on a 3406B....I didn't like it!
    And it was HEAVY!
    gonzo01 Thanks this.
  10. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    Its the same as a retarder right?
  11. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    It is a type of retarder, its in the flywheel housing and works off of oil pressure. They are known to leak more then they are worth.
    logtrucker25 Thanks this.
