Brakes issues
Discussion in 'Ask An Owner Operator' started by Rookie2020, Jan 10, 2021.
  1. Rookie2020
    Rookie2020 Bobtail Member
    35
    24
    Sep 22, 2020
    I have a 2005 freightliner century. Every time I hook on a trailer and drive away, later on, after 30 or 50 miles or so my trailer brakes lock after I have used the pedal many times and it happens on the traffic light mostly the time. The brakes release after I apply trailer handle brakes. What would be the problem? Any one can let me know what to do to fix it? I would appreciate your help, suggestions, or ideas. Thank you
  3. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Possible clogged airline. Original lines?
  4. SmallPackage
    5,535
    17,636
    Dec 20, 2019
    Marion Texas
    If its happening with different trailers I would check the tractor protection valve first. That is the valve on the tractor that the hoses to the trailer are supplied from.
    Diesel Dave and kemosabi49 Thank this.
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    If the trailer service brakes stay applied when you release the brake pedal and if you pull and release the hand valve this releases the trailer service brakes then replace the hand valve and check the exhaust line to be sure it’s not blocked (not likely). I’ve had this happen more than once.
    Rookie2020 Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,568
    13,293
    Jul 6, 2009
    If your tractor brakes are out of adjustment and the trailers are in adjustment. Guess which one is going to work harder and which one is going to work less.
    I had the same problem when I first started driving but I pulled the same trailer. Truck got new brakes and drums and adjusters. Problem solved.
    Make sure your brakes are good and adjusted. Could rule that possibility out.
  7. AModelCat
    160,549
    If it happens with every trailer, common denominator is the truck.
    In that case, I would be checking for a sticking valve in the truck's trailer service circuit. If the air won't exhaust from the service line, the trailer brakes will stay applied. The fact that applying and releasing the spike gets them to release tends to support that theory.
    Cat sdp Thanks this.
  8. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Abs valve, expensive, leaking break chamber leeking
  9. Rookie2020
    35
    24
    Sep 22, 2020
    Thank you for your help. I will look into it
  10. Rookie2020
    35
    24
    Sep 22, 2020
    Thank you for your help and I will look into it
  11. Rookie2020
    35
    24
    Sep 22, 2020
