Brakes stuck, peddle won't come back up. Cold temps.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Feb 10, 2019.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Hey guys hope everyone is doing well. So went to move the truck today (tri axle dump) when I hit the brakes they stuck on, brake pedal wouldn't come back up,fine last week was really cold here lately though. Heard about pouring some alcohol in the air line but don't know where or what line,or I can wait till it warms up a little. What do you guys think. Thanks.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    How old is the brake pedal?
  4. lwlevens
    623
    427
    Feb 9, 2018
    Truck is a 99 don't know if was changed out before though.
  5. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Might want to replace it and solve your problem.
  6. booley
    booley Road Train Member
    1,458
    10,017
    Feb 16, 2008
    You said the brake pedal won't come back up? My '05 International had one of those big aluminum pedals and I learned to spray some WD40 on the pivot point to keep it from sticking. Road salt from my shoes would get in there causing corrosion
    RustyBolt and Heavyd Thank this.
  7. xsetra
    xsetra Road Train Member
    5,171
    7,105
    Aug 21, 2011
    What kind of truck.
    Can you pull the brake pedal back up?
    Could be just dirt, spray and clean under pedal
  8. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    I am not familiar with your truck, but isn't mounted on the floor, or from above? And mentioned before, spray with WD-40 and try tomorrow it up.
  9. lwlevens
    623
    427
    Feb 9, 2018
    Mounted to the floor.It's a sterling dump truck.I pull the brake pedal up but it falls back down. I'll try spraying some WD on it tomorrow and see what happens. It worked last week,but it was also in the 50's. Maybe its frozen which airline do I pour alcohol into?
  10. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Sounds like the plunger is stuck. You’ll have to remove the pedal and pull the little rubber boot of and use channel locks to pull the plunger out and clean it reinstall coated in anti seize.
    IH Truck Guy Thanks this.
  11. lwlevens
    623
    427
    Feb 9, 2018
    Thanks now that you mentioned that the plunger is stuck in the down position, thanks I'll mess with it tomorrow.I'll need to build air pressure up first?
