Brakes went bad. Trying to troubleshoot.
Discussion in 'Ask An Owner Operator' started by John Joel Glanton, Jan 28, 2025.
  1. John Joel Glanton
    John Joel Glanton Light Load Member
    210
    303
    Sep 22, 2021
    Texas
    Looking for some guidance.
    Brakes suddenly started feeling weak, slipping and pulsing feeling when I step on the pedal. Everything looks ok to my eyes. Pads sufficient thickness. System holding air.
    Maybe the drums need to be replaced? How would I know?
    How would I know if it’s the trailer or my tractor? Company trailer = their money. Tractor repairs come out of my pocket.
    Edit: It just occurred to me I can drop the trailer and bobtail around to test them. Sorry I’m tired.
    Speedco is going to look at it tomorrow morning. Not trying to get hosed here. Thanks.
    Rideandrepair, tscottme and silverspur Thank this.
  3. JonJon78
    JonJon78 Road Train Member
    7,158
    39,485
    Jul 1, 2018
    I'd find a local independent shop with good reviews where your at and have 100% more faith in them especially with something critical like brakes before letting speedco look at anything.
  4. John Joel Glanton
    210
    303
    Sep 22, 2021
    Texas
    Bobtail seems fine. Must be the trailer. Sweet. Can keep a few extra coins in my purse.
    Rideandrepair and JonJon78 Thank this.
  5. Brandt
    Brandt Road Train Member
    4,514
    6,179
    Sep 17, 2012
    You should check the slack adjusters and see if they are working and not out of adjustment. Look at the drums and see if they have a lip on the inside from the brakes rubbing and wearing them out. The drums might need replaced and getting to thin and they can’t handle the heat. If you feel pulsing they probably out of round from heating and cooling and probably thin from getting used.
  6. JonJon78
    7,158
    39,485
    Jul 1, 2018
    How have things been going since that problem you had with the hose leaking or whatever that was? I remember it was not long after you started running with LS?
  7. Brandt
    4,514
    6,179
    Sep 17, 2012
    When hooked backup to trailer release the brakes push ped to floor to activate the automatic slack adjusters on Trailer and see if that helps. Do it 3 times
  8. John Joel Glanton
    210
    303
    Sep 22, 2021
    Texas
    Going well thanks for asking. Just minor things. Fuel gelling up in Indiana and almost freezing to death. Window button snapped off and window stuck down on the highway during a blizzard. Someone backed into me at the truck stop and tried to run off. When I caught up to him he denied it and wanted to fight me. Besides that it’s been good. Learning the ropes and getting good loads.
  9. OLDSKOOLERnWV
    18,389
    276,959
    Are the brakes on the trailer and tractor in adjustment?
    Customer whose trailers I pull to their customer has a flatbed, when I done my initial inspection I could plainly see the trailer brakes were out of adjustment.
    I adjusted the trailer brakes and rolled on down the road (first trip) with the trailer.
    Getting out of town and on the highway the brakes are used multiple times, when I got down to Winchester, KY over a 100 miles away I noticed the brakes weren’t holding like they were.
    After looking the rig over I noticed the brakes on the trailer were no where near close to the drums. Once again I adjusted the brakes which resulted in turning the adjustment 3 revolutions. By the time I got down in Tennessee the brakes were out of adjustment once again.
    Once back in town I spoke with the owner and ended up buying new slack adjusters and installing them myself. New adjusters seem to have solved the problems.
    Just something to look for on trailers you are not hooked to every day….
  10. 77fib77
    77fib77 Road Train Member
    10,625
    66,832
    Jul 7, 2010
    St Louis
    Bobtail weighs 21k. Empty trailer 13k? If your loaded your 80k. Very different then having 6 drums on a tractor trying to stop 22k vs 50k, assuming the trailer stops 30k.
    Rideandrepair Thanks this.
  11. John Joel Glanton
    210
    303
    Sep 22, 2021
    Texas
    Bad drums on the trailer. Getting it fixed now.
