BRAND NEW Cobra 29 Classic wont transmit or receive
Discussion in 'CB Radio Forum' started by Gliderdriver, Dec 27, 2017.
  1. Gliderdriver
    Gliderdriver Bobtail Member
    4
    Brand new unit out of the box...also brand new coax and antennas... Unit powers on, meter doesn't move at all, positioned all the way to left side. A "speaker click" when I key the mic... red lights indicates as if transmitting... but nothing both directions. Advice..
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Make sure you don't have it on "PA"
    BTShepp Thanks this.
  4. cmrdev
    cmrdev Medium Load Member
    370
    373
    Oct 13, 2017
    my buddy had that problem few months back with new cb in his rig. Turned out to be something the way the antenna or something was ground. Wish I new exactly what it was and don't feel like calling him because he wont s-t-f-u and ill be stuck on phone
    Gliderdriver Thanks this.
  5. cmrdev
    370
    373
    Oct 13, 2017
    hey man, did you do all the setup procedures in the manual? you have to tune the antenna and all that. There is a section that shows you how to do it in the manual. Takes like 3 minutes to do it. I remember my meter wasn't even moving once I installed my Wilson antenna on my cobra 29. I was like wtf? So I pulled out manual and saw the section and then I calibrated it. IT worked great.
  6. Ridgeline
    22,144
    113,517
    the red light indicates an antenna problem, don't transmit until you the antenna checked.
  7. Gliderdriver
    4
    Like a guy...I didn't. I will do that and check back.. thanks!
  8. Gliderdriver
    4
    Thanks! I am reading it could be about "bonding" the antennae?
  9. cmrdev
    370
    373
    Oct 13, 2017
    all I remebr is you have to hit some switch and then turn to channel 40 and then channel one and rebeat process. I forget but yeah something like that. HAve to key in the mike etc
  10. cmrdev
    370
    373
    Oct 13, 2017
    Go to section of manual where it says "calibrate for SWR" follow all those steps. PAge 5 I think if you have same manual. my truck in shop, otherwise I could tell you what switches and settings I have the rest of the radio on. Someone will chime in soon. but defiantely do the calibration
  11. Ridgeline
    22,144
    113,517
    No don't try to figure it out, take the antenna to someone who can check it so you don't screw the radio up.
    mike5511 Thanks this.
