Brantley Motor Express from Wilmington NC is a very bad company, you will haul 77,000# loads for .87 cpm. They will only give you $300 at a time on your fuel card, even on a 1900 mi load in which they will pay you on 1300 mi. Good luck if you need fuel on Saturday your dispatcher will shut off his phone.
Brantley Motor Express: Gimmick
Discussion in 'Report A BAD Trucking Company Here' started by the bambino, Feb 23, 2010.
sounds like they are a breath away from going under.....run forest....run.....
Beechvtail Thanks this. -
they can go under, over, around, or through for all I care. it cost me $1000 but i got out of the contract and parked the truck
I believe Cactusjack is right about this company. Something is definately up with them. If you could give us a little more background on this company and yourself, we could probably give you a better assessment other than...........run. Are the other drivers there saying anything?
From the little that you gave us it appears that they are trying to beat out all the other bottom feeders for the basement position. Good luck to you in surviving your ordeal. -
I have 10 years driving exp. i just bought a 2001 f'liner classic in december had to rebuild the motor right off the bat. $16,000 later i went on graigs list and found Brantley. Mistake #2
