Breakdown ,responsibilities
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Rocketfire, Dec 23, 2017.
  1. Rocketfire
    Rocketfire Light Load Member
    55
    31
    Dec 23, 2017
    I'm new at this particular trucking company in California. I'm an older woman and run solo all 48. This company , is not only cheap in maintaining their truck. But what is their responsibility, in repairing the truck. My starter isn't working. My boss had to pay X2 $300. Each time to pull start this truck. But won't replace starter. I am broke down two days now, truck won't start. Meaning I can't run the heater and I'm in Pennsylvania and it's way too cold for any comfort. I'm freezing actually. And he is not answering my texts or calls. What is my responsibility here? And what is his?
  3. nikmirbre
    nikmirbre Road Train Member
    5,429
    9,779
    Jul 27, 2011
    High Point NC
    I’d start looking for a new company.... you’re new and things aren’t gonna get any better.
    Broke Down 69, whoopNride, DTP and 3 others Thank this.
  4. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Can you get a flight home?
    You are very employable and don’t need this BS. Not your truck, not your problem.
    drvrtech77 and Lonesome Thank this.
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Wow. That is crazy. Company is responsible to keep truck running. And keep truck legal. Right now it's not running. Take a bus home. Leave the truck where it is. Unless you are loaded.
    Lonesome Thanks this.
  6. Lonesome
    Lonesome Mr. Sarcasm
    11,160
    22,892
    Dec 15, 2007
    Northern Indiana
    His responsibility is to fix the darned truck! Tell him you're leaving, if it ain't fixed correctly in the next 2 hours.
    Broke Down 69 Thanks this.
  7. Cat sdp
    Cat sdp . .
    20,969
    73,057
    Apr 8, 2012
    Orion's Belt
    Saturday night before Christmas Eve ... it ain’t getting fixed right tonight.
    Bump start again is your best hope....and don’t shut it off.
    Or call the local truck (brand of tractor) dealer and have it towed in . And take a bus/ rental car home.......
    It’s your responsibility to make sure truck is in safe place..... that’s all....
  8. Diesel Dave
    8,714
    24,941
    Jan 20, 2010
    Hesperia, Ca.
    What’s the starter doing ? Get someone to help you, while someone is hitting the starter at the same time try starting in it. Probably silenoid is stuck. Or, get someone to pull you and dump the clutch
    wore out Thanks this.
  9. wore out
    wore out Numbered Classic
    15,920
    192,647
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would try to get it started probably even though it isn't actually driver responsibility. I would then immediately see if my fuel card was working. It kinda seems like the ship may be a sinkin
    bzinger and Jazz1 Thank this.
  10. Brandt
    Brandt Road Train Member
    4,503
    6,161
    Sep 17, 2012
    That's jam to be in, maybe a hotel room or bump start again. I can't see it getting repair till Tuesday evening that would be lucky since shops will be backed up with work that was not finished today.
    TA or Petro might be able to replace a starter but seems like boss doesn't wants to pay anyone to fix it.
  11. Brandt
    4,503
    6,161
    Sep 17, 2012
    You can hang out in driver lounge if you at good truck stop. It's supposed to snow in PA and will be to cold in truck without heat I would think.
