Breakeven
Discussion in 'Ask An Owner Operator' started by BJnobear, Sep 12, 2010.
  1. BJnobear
    BJnobear Heavy Load Member
    969
    306
    Aug 24, 2010
    PCB, FL
    Just wondering if 1.35-1.40/mi. is a good breakeven for flatbed owners.:biggrin_25521:
  3. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Well that all depends. What are your costs?
    Truck payment?
    Trailer payment?
    Insurance?
    Fuel?
    Maintnance?
    broker/load board/factoring fees?
    Tires?
    Driver pay?
    How many miles are you going to run? Empty & loaded?
    All those costs above & more are needed to figure a good estimated cost per mile. If all those costs divided by miles equals less then $1.35-$1.40, then everything else is profit.
  4. BJnobear
    969
    306
    Aug 24, 2010
    PCB, FL
    That is already calculated. I was wondering if that range was normal or not.
  5. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Uh, what was the question again ??
    Was it good rates, or break even ?
  6. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    with current fuel prices, i fall in that range. :)
    but keep this in mind, you dont wont to haul all your loads at breakdeven. it takes cost plus.
  7. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    How many miles in a week are you figuring that on?
  8. Bigray
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    Les, if your asking me i est. 107k / yr.
  9. Les2
    5,150
    2,288
    Jul 25, 2008
    I was asking both of you. Thanks
  10. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Well since you believe you should keep your numbers a secret, then it will nearly be impossible to give you an accurate opinion on your costs & your possible breakeven.
    You have to know what your cost per mile is before you can determine if $1.35 is an appropiate rate for yourself. If your cost per mile is $1.25, Then $1.35 would be profitatble to a point. If the load is right there next me, I'd haul it. But if I had to deadhead 400 miles, then that load would no longer be worth it & will not go on my trailer.
    But I don't expect you to listen to me. And you will most likely follow my path to failure. The difference would be that I saw the doom & gloom, & fixed my issues. You not knowing anything about the O/O side won't see the warning signs & keep barrelling off the cliff!
  11. BJnobear
    969
    306
    Aug 24, 2010
    PCB, FL
    Sorry, what I meant was that range is where the calculations say I would need to be to breakeven. Obviously I would look for $1.60+ loads. Or is that considered "Cheap Freight"?
    I actually have built a MS Excel spreadsheet to calculate all of this. I just don't have an idea of what the actual freight rates are running at anymore. I would be happy to share it with ya'll (that way you can tell me if I forgot anything...). Just PM me! (I think I can PM now...)
