Bridge tandem axle weight limit question
Discussion in 'Questions From New Drivers' started by Requiemforroksy, Sep 7, 2016.
  1. Requiemforroksy
    Requiemforroksy Bobtail Member
    42
    4
    May 18, 2013
    Hi all
    Wanted to ask a question regarding a sign over a bridge.
    There is a bridge near me that has a sign that says "weight limit - tandem axle 24,000 lbs" next to it (behind some trees no less). No other weight limit signs are present. Does this mean that you can cross the bridge as long as each of your tandems is less than 24k? For example if I'm running 9000/18000/20000 than its okay? It doesn't say that it's a gross limit of 24,000 just tandem limit.
    Just wanted to clarify,
    Thank you
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    That's how I would interpret the sign
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    I would just go with the axle weights, otherwise it should say GVW.
  5. okiedokie
    okiedokie Road Train Member
    13,319
    103,619
    Jun 13, 2011
    PNWET
    I'm guessing it's a short bridge span.
  6. Requiemforroksy
    42
    4
    May 18, 2013
    Thats normally what it would be but this bridge is probably 160 feet or so. Definitely big enough to fit the whole truck.
    okiedokie Thanks this.
  7. okiedokie
    13,319
    103,619
    Jun 13, 2011
    PNWET
    Sounds like your good to go.
  8. Requiemforroksy
    42
    4
    May 18, 2013
    Thats what I figured, I just wonder why they would put tandem limits and not just gross limit. I guess there is only so much weight the bridge can take per a small area but if you spread it out its fine.
  9. MACK E-6
    49,637
    233,976
    Well, limiting tandem weights will certainly impact your gross, of course.
    In the case of that particular span, dump trucks are the primary target, IMO.
