Brief puff of white smoke on highway
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Manfrmbklyn23, Dec 10, 2014.
  1. Manfrmbklyn23
    Manfrmbklyn23 Bobtail Member
    28
    Mar 2, 2012
    Brooklyn, NY
    International 9200i C15 475HP for the last few days, every so often on the highway (mostly hills) the truck will bog out or become sluggish and let off a medium cloud of white smoke. It happens very quickly and then it's back to running normal again. Almost never happens during local driving. Strictly at higher speeds and I could be imagining this but it seems like hills make it worst. Any clues as to what this can be?
  3. Truck engine machinist
    Truck engine machinist Light Load Member
    195
    185
    Dec 2, 2011
    USA
    Could be combustion gases getting past the injector fuel o-rings, causing injector misfire under heavy load. Does it go away while still under heavy load, or is it when the load lessens?
  4. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    White is unburnt fuel or water, if it isn't losing coolant then it's probably related to the DPF. How often does it regen?
  5. Manfrmbklyn23
    28
    Mar 2, 2012
    Brooklyn, NY
    Hey guys, thanks for helping out. Just left the shop and it turned out to just be a really dirty water separator fuel filter. Thank goodness! I had them out my injectors on the computer just for my piece of mind and they are fine. Lucky me. I will sleep good tonight.
