Broken and stuck c-15 acert exhaust manifold stud help!!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bstromback2002, Nov 23, 2013.
  1. bstromback2002
    bstromback2002 Light Load Member
    133
    24
    May 12, 2012
    wi
    Does anyone have any tips or tricks on removing the stuck studs or removing the broken one??? We are somewhat afraid to heat them since they are so close to the head gasket. So any ideas or help would be great thanks!!
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Soak them good with penetrating oil. You might tap them with a hammer to break any rust/corrosion. Once you get that initial break loose they should come out easier.
    Is there any bolt left? If so use vise grips as close as you can to the base and as tight as you squeeze them.
    If they are broke flush then it's drill and easy out. Use a center punch to start the drill hole.There is nothing easy about it.
    Make sure you chase the threads when you do get them out.
  4. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    You can get a proper tool to guide your drill bit. Very rarely you have to drill the whole thing out. Usually a smaller drill and an easy/out works well.
    Cetane+ Thanks this.
  5. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    A left handed cut drill bit sometimes does the trick, Don't use heat until you have to, there is enough carbon in those studs to really harden them and then you need a carbide drill bit......... NOT a lot of fun
    The drill guide in morehp's reply along with a left hand bit and the advice is the earlier posts should work well.
  6. bstromback2002
    133
    24
    May 12, 2012
    wi
    Got it done the three stuck studs we heated then soaked with Schaeffer's penetro while They were still hot let them sit and cool completely then put a vice grips on them and turned on it while hitting the end of the stud with a hammer till they came out. The broken stud we got lucky with a magnet drill and drilled it out the picked what was left out and it was good to go. What really sucks is I had two cylinders missing the exhaust sleeves two more were broke and just rattling in the head and my top turbo is going to have to be replaced because the exhaust wheel is not to healthy looking.
    CruzControhl2 Thanks this.
  7. bstromback2002
    133
    24
    May 12, 2012
    wi
    That jig is pretty neat Morehp if it would have been the back studs that would have came in really handy
  8. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I've drilled them out several times always with a hand drill and a regular bit. The hardest part is getting a good start as the stud can be slightly below the surface and broke off at an angle. Getting the bit to start without walking can test your sanity. drill the stud all the way through there is a small gap between it and the head so you can feel it push through. Once it's drilled you can get penetrating oil to the back side of the stud which helps. Then use and an easy out. DONT BREAK THE EASY OUT!!!!
    That's if they are broke just went back and read your post again. If they are not broke remember the factory torque on the studs is 28ft lbs if I remember correct so they will be hard to turn out.
    I would never install them and torque them that high.
  9. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    I always get them out by welding a nut to the stud even if there flush. Arc welder seems to work best.
  10. Ashman_42
    Ashman_42 Light Load Member
    248
    64
    Aug 14, 2011
    Monaco tool sells that jig that Morehp posted a pic of, with a special diamond bit drilling studs even at the back of the head is super easy. I've also done gearhead's trick except I weld a washer instead of a nut first, then weld the nut to the washer on the outside of the nut. Welding inside of a 3/8" nut and getting good adhesion to the stud vs using a washer first works much better.
  11. wore out
    wore out Numbered Classic
    15,367
    185,522
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Steady pressure and vibration is the key. Use box end wrench on nut, air hammer with blount tip bit. apply steady pressure on wrench while vibrating the end with hammer.
    Klleetrucking Thanks this.
