Broken front diff from gearing down
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Sep 5, 2018.
  1. truckerbangin
    truckerbangin Light Load Member
    266
    44
    Jan 22, 2013
    had a pretty heavy load and had to gear down fast to avoid a crazy driver with the Jakes on high but when downshifting from 4l to 3h I heard a crack the 3h to 3l another crack so I sunk the clutch and got truck to a stop. When coming off the clutch I heard the sound of a gear slipping. Truck moves with or with out diff lock on, the noise is heard with or without diff lock on.
    The gear box appears to shift fine and I don’t feel any vibrations coming through the gear stick.
    Has anybody ever experienced this before to know if it’s a front differential issue or a gear box issue.
    Truck has a 18speed
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Does driveshaft spin and truck not move that is bad diff. May have to ck back box on trans?
  4. truckerbangin
    266
    44
    Jan 22, 2013
    On a flat surface it moves with minimal to mild cracking noise. On a incline cracking/gear slip noise get louder and faster but I did notice the front drive shaft reacts when you hear crack/gear slip
  5. AModelCat
    159,363
    Tandem drive? What locks are you engaging: Diff or interaxle?
    Normally when something lets go in a diff you'll have no drive with all the lockers disengaged. If one of the countershafts in the aux section went out you'd hear gear noise but would still have drive from the other countershaft.
    With that much stuff crunched up it'd be pretty easy to pinpoint what failed. Just check the diff and transmission magnetic plugs for shrapnel.
    pushbroom and spsauerland Thank this.
  6. Mauricio.5283
    Mauricio.5283 Bobtail Member
    45
    27
    Oct 20, 2017
    Did you drain it? Check the fluid for metal shavings.
    Sounds like your auxiliry box, if the noise was on a specific gear I would say drop the whole transmission but your auxiliary handles the High and Low Range and the Drive and Overdrive gears, which was what you moved when the transmission failed.
    Start by draining the oil and take it from there. Eaton website has al the info for free if you need a diagram to understand some things.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,477
    6,515
    Aug 26, 2014
    Stick a magnet to the bottom through the fill plug opening. What do you find? That is on both diffs.
  8. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Sorry forgot the 1st thing you must ck is a U-Joint going bad, have to ck them before you go taking everything else apart, a bad u/joint can make all kinds of racket before it flys apart
    BoxCarKidd Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    If your truck makes a CLAC CLAC CLAC CLAC CLAC CLAC at 2 mph when you try to go anywhere it's probably really deep inside your rear or rears.
    We used to call that sound the click of death. Trucks have been cheaper to junk than fix with that kind of damage.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Or slip yoke in the driveshaft between the trans and front diff. Should have one on the last shaft hooked to the front diff.
    baha Thanks this.
