Broken Rear Motor Mount Bolts
Discussion in 'Kenworth Forum' started by Fishell Trucking, Feb 12, 2012.
  1. Fishell Trucking
    Fishell Trucking Light Load Member
    128
    33
    Jan 11, 2011
    Raymond Montana
    About a year and half ago I put new rear motor mounts in and ever since that I have had the bolts braking. Just on the rear mounts. This happens about every 30-50000 miles. The front mounts are also new have had no problems with them. I have the polly mounts in the rear and purchased them via E-bay. If I remember, I'm sure I crossed them with the OEM #, but If I didn't and they where the wrong mounts is this possibly the problem? I am using a grade 8 metric bolt just as the ones that come out. It just snaps the top off of them. Not at the same time, one time it will be the drivers and the next it will be the passenger side. I have talked to a few shops and nobody has dealt with this issue before. Oh ya this never started happening till I changed the mounts. Anyone got any ideas.
    Thanks Terrance
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Have you tried going back to an oem mount to see if it fixes the problem?
  4. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    It sounds like there is some vertical movement against the bolts to be snapping the heads off. Do the poly mounts have steel sleeves in them? Are the bolts being over torqued at installation?
  5. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Are you re-torquing the bolts after you install them?
  6. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    Yes the poly mounts have steel sleeves. What is the torque spec for these ? I have just tightened them tight with a ratchet.
  7. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    You need to make sure they are tight my guess is there not tight enough and the engine is moving around and slamming up aginst the head of the bolt o don't torque them I use a 1/2 impact gun also where are you buying bolts? Might be getting cheap bolts autozone and place like that will sell u so called grade 8 bolts but there cheap quality I would go to caterpillar and get bolts and try that
  8. KaptainKenworth
    KaptainKenworth Bobtail Member
    33
    18
    Jan 19, 2012
    Alberta Canada
    Have a look at down the mounting holes when the eng is sitting on them.. do the holes line up from the leg thru the mount and onto the saddle.. i have run into a circumstance where in between the frame and lower mount saddle there is a 1/4" spacer.. if that is missing it can put undue stress on the mount.. otherwise make sure the leg bolts are tight on the rear structure. typically the mounts just vary with durometer rating( how soft they are). also make sure the tits are ok on the lower saddle and the holes are not oblong..
  9. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    I think I might have found my problem. I order new OEM rubber mounts and installed. In the process of taking out the poly mounts I noticed on the driver side that on the bottom side where the mount sits on the two tabs that keep it in place that it was not sitting on the tabs the right way and messed up the holes. With that in mind I think this was letting the mount move just enough to brake the bolt over a period of time. So again no one to blame except myself. Hope this fixes it. Time will tell. Again thanks for all the info.
  10. KittyKicker
    KittyKicker Light Load Member
    196
    100
    Dec 27, 2015
    Hahaha, ^^^^^he said "tits"!^^^^^
    TGUNKEL Thanks this.
  11. Fishell Trucking
    128
    33
    Jan 11, 2011
    Raymond Montana
    Kitty kicker thats a nice looking W9 you have
