Broker lied about the reefer temperature
Discussion in 'Ask An Owner Operator' started by Olec, Jul 15, 2025.
  1. Olec
    Olec Bobtail Member
    44
    43
    Jan 23, 2025
    The broker misrepresented the temperature for the load.
    It was supposed to be Fresh, it is Frozen at -10.
    What do you do where there is 45 degrees difference?
  3. Olec
    Olec Bobtail Member
    44
    43
    Jan 23, 2025
    And if people are here to say to deal with it, it isn’t them taking risks.
    The reefer is to hold the temperature, not cool it down. So, in the summer I don’t book loads at -10 when it is in the 90s or higher. At times, they do load a warm product, then the carrier mostly is taking liability for it, not the shipper.
    Iamoverit and Ok big boy Thank this.
  4. wichris
    wichris Road Train Member
    4,293
    8,647
    Jan 17, 2011
    Maybe get a van and eliminate your problem. Going to pull reefer you'll have different temps regardless of the outside temp which is no problem if you have a decent unit/trailer.
  5. Concorde
    Concorde Road Train Member
    4,716
    16,856
    Jun 29, 2016
    West Melbourne Florida
    Get a higher rate or refuse the load, quite simple.
    RockinChair, Siinman, Tb0n3 and 2 others Thank this.
  6. Ok big boy
    Ok big boy Light Load Member
    89
    94
    Jan 22, 2014
    So you booked it, but have not loaded it ?
  7. abyliks
    abyliks Road Train Member
    3,892
    9,102
    May 2, 2010
    ludlow MA
    You ran it loaded at the wrong temp or you showed up to load and it was the wrong temp?
    RockinChair, Siinman and 77fib77 Thank this.
  8. Olec
    Olec Bobtail Member
    44
    43
    Jan 23, 2025
    Canceled on them since the rate was low. They misrepresented the temperature.
    I arrived with 35 degrees on the reefer, and they wanted quickly load the product and change it to -10. That’s 45 degrees difference.
    Good for you if you want to be liable for drastic changes in the temperature in the last minute. Was released from the load.
    Sons Hero, Iamoverit, MACK E-6 and 6 others Thank this.
  9. Olec
    Olec Bobtail Member
    44
    43
    Jan 23, 2025
    I have never seen anyone wanting to load the trailer so fast before the appointment time.
  10. Concorde
    4,716
    16,856
    Jun 29, 2016
    Good for you, I’d have done the same.
  11. Eddiec
    Eddiec Road Train Member
    2,248
    3,453
    Feb 2, 2015
    Sounds like they had sketchy product to begin with and they wanted you to take the hit for it!
    Iamoverit, Siinman, Olec and 1 other person Thank this.
