Building a 20' dump bed, should it have a positive camber built into it?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by greaseburner, Jul 15, 2017.
  1. greaseburner
    greaseburner Light Load Member
    155
    45
    2' x 8 'x 1/4" main rail tubing
    4" x 4" x 3/16" upper and lower outer edge rails
    4" C channel 12" on center front to back floor supports
    1/4" AR400 steel for floor
    1/4" x 12" AR400 steel for plate that angles from floor to sidewall at an approximate 45° angle
    3.5" x 3.5" x 3/16" 4' uprights 2' spacing
    3/16 AR400 for side plating
    Question being, are dump truck beds built with a slight positive camber to the bed or are they built level?
    Thanks
  3. greaseburner
    155
    45
  4. SL3406
    SL3406 Medium Load Member
    550
    1,487
    Jan 10, 2011
    Oklahoma
    They're built level.
  5. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Are you building your own dump body?
    I think that would be a huge project to take on, hopefully you have a good shop set up for that project.
    Also pretty curious on the specs and intended usage for a truck that's getting a 20' box.
    I just put a brand new dump body on my 2000 truck last fall. They are pretty spendy, by the time I had the FET figured in I was north of 40k, but I tell you what it was some of the best 40K I have spent in trucking.
  6. Caterpillar Cowboy
    837
    607
    Nov 11, 2010
    Wyoming
    Not trying to be a complete negative Nancy, without getting out my build sheet or quotes from other outfits, it seems like you're on the right track, and I admire your ambition.
    You may want to look at lining the sides and tailgate with either plywood or UHMW, it will keep your box looking much better for much longer, but leave that floor steel!
    Also a high lift tailgate comes in so handy, I would have to be in a very penny pinching mood to order a dump body without. If you're building your own it's a no brainer to put it on, unless you are strictly going to be hauling light aggregate.
    And to answer your original question, Flat.
  7. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    What brand body did you have installed?
  8. Dirty-Low-Walker
    359
    543
    Dec 17, 2013
    I have never seen a dump body that wasn't level to the frame.
    This is a interesting thread, and a great deal of work for someone, i hope you do well with it!
    Please post pictures as you proceed.
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Will that truck do very little miles in a year?
  10. greaseburner
    155
    45
  11. greaseburner
    155
    45
    around 50k per year....
