Bunk AC problem
Discussion in 'Peterbilt Forum' started by devildog3531, Jul 28, 2017.
  1. devildog3531
    devildog3531 Light Load Member
    119
    31
    Jul 5, 2015
    Hello drivers, wanting to know if any of you experienced this problem. I have a 07 peterbilt 387. Both my front and bunk ac was working perfectly til yesterday. Now my bunk ac won't blow at all. I have to depend on the cab for air when I'm parked. Any suggestions? I would appreciate it.
  3. Allow Me.
    10,686
    12,265
    May 28, 2009
    Rancho Mirage, Ca.
    probably the switch or the vent directing the air. Or the flap
  4. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Check your fuses. Did it stop blowing air all together, or is it blowing air just not cooling?
  5. devildog3531
    119
    31
    Jul 5, 2015
    Just stop blowing period... nothing
  6. whoopNride
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Check your fuses, if you don't find one blown, get a test light and check to see if you have fire at the blower motor. Probably either the fuse, switch gone bad or blower motor gone bad. You can narrow it down with a cheap test light.
  7. Mudflaps
    Mudflaps Light Load Member
    58
    57
    Oct 1, 2016
    What about bunk ac blowing warm air, cab ac blowing cold air. Any suggestions.
  8. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    Expansion valve?
  9. rastaman38
    rastaman38 Bobtail Member
    7
    4
    Jul 19, 2017
    The expansion valve has nothing to do with the blower assembly, it is as WhoopNride said.
  10. driverdriver
    4,254
    5,283
    May 30, 2011
    What are you smoking?
  11. rollin coal
    rollin coal Road Train Member
    13,315
    26,960
    Mar 29, 2008
    TN
    Are Pete's similar to KW's? There's a resistor near the bunk blower motor, and the cab one too, that gets dusty/dirty over time and shorts out. It's really cheap and easy to replace. I forget exactly what it's called. When it goes your blower motor will quit working. Sometimes I think it will only have low speed but not high speeds. Motors get old and start dragging too.
