Bunk blower not blowing
Discussion in 'International Forum' started by toddn1xhr, Dec 8, 2013.
  1. toddn1xhr
    toddn1xhr Bobtail Member
    8
    May 8, 2013
    Pittsfield, Ma
    As I sit here in London, Oh, I am finally tired of trying to figure this out.
    I have a 2006 9400i, when I push the button to turn on the bunk controls, the light on the main climate control comes on for the bunk, but I am unable to get the bunk controls to work.
    I have checked the fuses and relays in the glove box and that is all good. The one thing I noticed is the blower switch on the bunk control panel was very rusted when I removed the panel and it might be bad, but short of replacing it, is there any way to test.
    Also, does anyone have suggestions on what else I can check.
  3. "Hang - Man"
    "Hang - Man" Heavy Load Member
    737
    583
    Nov 12, 2013
    Western PA
    A simple switch just connects 2 wires together when you turn it on -- if it has just 2 wires try jumping them together if you can !
    baha Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    If you are relating to the heater then it you won't notice anything at first. The unit has to heat up before it turns the fan on. It's like a 2-5 minute delay. Turn it on and wait.
    If it is something else let us know.
    On some there's an override switch up front on the dash.
    We need a little more detail what's not working. A picture of the panel would help.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    use test light to ck. for power in one of wires at turn fan switch.
    "Hang - Man" Thanks this.
  6. "Hang - Man"
    737
    583
    Nov 12, 2013
    Western PA
    Yeh try what CondoCruiser or baha says, he would know better - i have to assume that wiring in the trucks have become more complicated than what i said --but then again if it is a simple toggle switch maybe not.
    I have to assume that those units (I have 0 experience with them) may have a thermal breaker also.
    I do have a mechanical background --but 0 experience with the diesel truck mechanics --or bunk heaters.
  7. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    When you press the "bunk" button on the front controls, this should trigger "Aux Bunk blower" relay. If not, the button on the main control may have failed. Just because the light comes on, doesn't mean the signal is going out. If the auxiliary bunk relay is working, this is sending power to the fan speed control knob in the bunk control panel. This power is sent through wire #75AS, green in colour. After that, the different speeds go through different circuits with different power sources. It is extremely unlikely to have all fan speed circuits fail at the same time to cause the fan to not work at all. If the control is getting power, chances are the blower motor itself is no good. The rust you found is probably the root cause though. Also, there is no time delay. When you turn the controls, the fan will be on.
    QUALITYTRUCK Thanks this.
