Bunk radio control says NO LINKIs there anybody out here in Trucker
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Rascal28950, Feb 17, 2011.
  1. Rascal28950
    Rascal28950 Bobtail Member
    Buckhannon, WV
    Is there anybody out here in Trucker World that knows how to fix the Bunk Remote Radio control when it says "NO LINK"?:biggrin_25511::biggrin_25523:
  3. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    NO LINK?
    It is either "hard-wired" to the radio or wirelessly connected. That "connection" has been interrupted.
    Owner's Manual could give you a clue about where to look, or perhaps if you are friendly with a tech at your local dealer, he could "help".
  4. Rascal28950
    Buckhannon, WV
    Thanx Pur4, yes it is hard wired and I pulled the panel and found the harness that goes to the remote and I unplugged the closest pigtail and it shut down the main radio up front...
  5. fl_parrothead
    fl_parrothead Bobtail Member
    8
    Oct 18, 2011
    Cape Coral, Florida
    With the key on, pull all of the radio fuses, turn key off, wait a few sec and put the fuses back. The bunk radio should sync again. It worked in my 2011 prostar
    Scorcher21, lv gn and Ex-Con-Trucker Thank this.
  6. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    My 2011 prostar is does that eveytime it comes back from the dealer. And did it once on it's own. I will try pulling the fuses tonite when I get to work. Thanks!
  7. lv gn
    985
    469
    Jun 23, 2008
    las vegas nv.
    I pulled the one radio fuse and worked like a charm!
  8. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Ooo... gonna have to try this when I get the truck back. It wasn't working... and then it was... and then it wasn't... No idea as to how or why, but I will try this.
  9. Scorcher21
    Scorcher21 Light Load Member
    146
    141
    Apr 20, 2011
    Crossville Tn
    ty very much, same deal came back from service with no link. was getting real annoying to have to get up and throw some pants on to go into the cab to turn alarm off. a couple places said to remove both radio fuses, I just turned the key to the on position with the radio on, removed F2-E 'entertainment radio memory', turned the key off, waited 20 seconds or so, popped it back in and turned the radio on using the bunk unit. worked like a charm. now i can continue being lazy in the morning lol. BTW mine is a '09 prostar your fuse assignment may be different, look before you pull. :biggrin_25514:
    wBrownLD Thanks this.
  10. Ex-Con-Trucker
    Ex-Con-Trucker Medium Load Member
    440
    395
    Oct 1, 2011
    Atlanta, Ga
    you rock man... I have a little case of ocd, and hate when #### doesn't work. Pulling the fuse worked like a charm.
  11. Roadrealtor
    Roadrealtor Road Train Member
    1,061
    1,070
    Aug 7, 2010
    Fort Myers, FL
    Too cool!!!! It fixed mine and I fixed the flatbedder parked next to me.
    I had it to a dealer and they charged the company (international warranty dept) for a new bunk radio. Chances are that was the highest price fuse ever sold.
    Be safe drivers.
    Road Realtor
