Burning coolant, but it isn't in the oil
Discussion in 'Freightliner Forum' started by Michael H, Oct 12, 2020.
  1. Michael H
    Michael H Medium Load Member
    466
    1,023
    Nov 3, 2015
    Arizona
    Howdy all,
    I have a Detroit S60 14L in my Columbia. It is burning coolant. After I shut it off to fuel, it blows white smoke for a couple of seconds. I am losing coolant, but no leaks and the hoses are new.
    I checked the oil, no water in it.
    Where could coolant be making its way to the exhaust without going through the engine?
    Thanks much!
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    EGR cooler internal leak. Have it tested.
    Rideandrepair, Hulld, magoo68 and 3 others Thank this.
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Agree, I would check the EGR cooler first.
    Rideandrepair and 650cat425 Thank this.
  5. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Head gasket
    Rideandrepair Thanks this.
  6. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Thanks much! I'll start with the EGR
  7. bad-luck
    bad-luck Road Train Member
    3,261
    5,980
    Nov 16, 2013
    Baltimore, Maryland
    EGR cooler. Easy way to check it is: there is a pipe from.the EGR cooler that runs over the top of the engine into the intake manifold. Disconnect it near the intake manifold. If the pipe is wet inside your EGR cooler is leaking. To confirm start your truck, use your hand to push the accelerator to the floor 5 times. This will cause the EGR to kick in. And you should see coolant in the pipe
    Rideandrepair and Michael H Thank this.
  8. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Thanks much! I'll give it a whirl after I'm empty tomorrow. I don't want to push my luck under load...
  9. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Update. I'm so ashamed...
    After having the dealer order me a new EGR cooler and bringing it in, I have a verdict.
    It was a loose hose clamp. Tightened it up, no codes, all is well. Geez.
    Rideandrepair and QUALITYTRUCK Thank this.
  10. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Update to the update: Kick in the pants time. Turns out, I need a new VGT turbo. This will also mean an intake manifold, due to rusted bolts. FML.
  11. D.Tibbitt
    142,518
    Why?
