Looking to buy a truck
considering either a freightliner cascadia 126 - used - detroit - maximum 350k miles - 475hp minimum
my budget would be around $100,000 for this truck.
my other option that ive been considering is buying an older truck such as a w900 or a pete with a cat motor and running that.
But alot of the older trucks i see online have 1 million plus miles.
let me know your thoughts and what i should do
Buying a truck advice?
Discussion in 'Ask An Owner Operator' started by hsingh_2, Aug 29, 2024.
Page 1 of 8
Have you taken a look at current freight rates? It's your money to do with what you want, but definitely not a good idea right now.Opendeckin, Iamoverit, Kenworth6969 and 7 others Thank this.
New & Used Commercial Trucks & Trailers For Sale | Truck Paper
Aug 14, 2024 — TruckPaper.com is your headquarters for new and used trucks, trailers, and related equipment. Buyers can find used truck listings from hundreds of manufacturers, …OldeSkool Thanks this. -
You can buy a lot more truck for 100k than a half wore out Cascadia. At least right nowRideandrepair, AModelCat, W923 and 2 others Thank this.
Quick tip - look at engine hours instead of miles. Many truck that I looked at when I was buying my cascadia has altered mileage - be on look out for that. I buy only used trucks with APU, so the idle hours are on APU not main engine.
Don't buy a truck with more than 20,000 hours on it. The average milage for company driver is 100,000 miles per year, so if a truck is 7 years old and only has 400,000 miles on it should be suspicious.
Also about horsepower, I was looking to buy a 500 HP cascadia but ended up buying 400 HP. I found out they all the same engines and you can just update firmware at dealer to turn 400 hp to 475, 455, 425 HP whatever you want.Rideandrepair and Ok big boy Thank this. -
I’d do the Cascadia, but I would think you could get a whole lot less miles for that much money. I bought a 2017 Cascadia sleeper truck for $53,500 with 345,000 miles. Was a very good truck for years. I got it deleted and never gave me any serious trouble.Rideandrepair and Ok big boy Thank this.
i see KW 680 new Modell 2022 with 380000 for 77k
Rideandrepair Thanks this. -
If you can’t turn a wrench don’t bother with an old truck, and absolutely NOT on a used emission truck, brand new only
Ok big boy, Short Fuse EOD, AModelCat and 5 others Thank this. -
Invest the 100K on something that will give you more of a return than that truck right now.
Rideandrepair and Iamoverit Thank this. -
Lol was going to ask the same thing. I think the general consensus drivers have is that if they can make money driving for someone else, owning a truck would net them even moreRideandrepair, Concorde and ducnut Thank this.
Page 1 of 8
