Hi everyone,i'm a soon to be o/o looking for buying a used truck.I've noticed that many of them have 2.64 gear ratio,wonder how that would work out with LIGHT-HEAVY dry van loads, primarily utah, montana,idaho - going to midwest area?truck Volvo D13 455hp,ishift Thanks!
BUYING A TRUCK GEAR RATIO ADVICE
Discussion in 'Ask An Owner Operator' started by mmhasan1, Jan 14, 2021.
Page 1 of 3
IDK, 2:64's sounds like flatland gearing. For any kind of hills, I'd think nothing lower ( numerically) than 3:50's.
black_dog106 and TallJoe Thank this. -
2.64 rears are only part of the Total ratio combination and engine that matches it ...
The question is wayyyy too broad.
You see allot of modern engines with 2.64 and OD trans because the engines these days have a much lower RPM sweet spot and peak TQ.
Volvo for example makes peak TQ between 900-1050 on XE engines and generally about 1150-1200 on regular engines.
One of my trucks is a 2.47 with OD and the TC - XE motor, it pulls as well or better than other older trucks with 3.08-3.55 rears I've found.
455hp should be an XE spec, I'd recommend 2.64 - 2.85 in the regular XE engine, it's fantastic ..2.47-2.85 in the TC...
The 3.08 is for lower speed cruise(55-68 max) and generally not optimal against a High TQ/Low RPM motor that's ran at 65+ MPH regularly.Last edited: Jan 14, 2021
flood, Tug Toy, Crude Truckin' and 3 others Thank this. -
What is the gearing in the transmission? Is that a direct drive transmission?
Can someone explain again, please, why an inadequately chosen gear ratio would work adversely to the type of work?
What is really at stake? Wear and tear, mpg , climbing speed?
When defining specs is it that significant? -
TallJoe Thanks this.
The direct drive spec would be in the 2.25 area with a newer model Low RPM/High TQ motor -
Atlaw4u Thanks this.
Page 1 of 3
