Buying own locks
Discussion in 'Questions From New Drivers' started by TonyB, Feb 19, 2009.
  1. TonyB
    TonyB Bobtail Member
    14
    Wakeman, OH
    Well, I just accepted a job with Shaffer and in talking to them about what I needed to do next, I found out that I had to pay $160 for my own 'king pin lock' and door lock. Is this a charge that drivers normally have to pay or do companies normally supply these for their drivers?
    Also, since the training is in Columbus, OH and I live just outside of Cleveland, they're having me just drive myself down there to training or have someone else drop me off. Is it usually up to the driver to find his own way to training if it's relatively close (2 1/2 - 3 hours)? Also, any idea why they do their 8 weeks of training before they do their orientation? Isn't it usually the other way around?
    Just wondering. I've read posts about companies not reimbursing drivers for lumper fees, tolls, etc. and I wanted to see if Shaffer may be "one of those companies."
    Any info. would be much appreciated.
  3. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    Well, training before orientation makes sense since you need to obtain the CDL before they can hire you. As far as the driving thing, not sure, since I went to an independent school less than a half hour from where I live. When I got hired, I did get my own ride, but that was my choice . . . I don't like buses.
    The king pin lock and related locks are SOP for many companies. Those things are not cheap, and it is for rig security.
    Just about every company out there reimburses for lumper fees, etc as long as you follow their procedures for getting reimbursed.
  4. TonyB
    14
    Wakeman, OH
    Thanks for the info. - I appreciate it!
    As for the training, I don't mean schooling to get my CDL -- I'm a recent graduate from an outside school. I mean going out with the driving trainer for 8 weeks once you're hired. I thought most of the other companies I spoke with had their orientation first and then sent you out with your trainer??
  5. Lilbit
    16,583
    12,233
    Aug 4, 2008
    OK, that is a bit odd. Usually orientation is before they send you out with a trainer, and then have another short one after training before they put you in your own truck.
  6. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    King pin locks are about 25.00 plus tax.
    Master Lock padlocks 3 for 12.00.
    Unless they have a special lock which I doubt, I believe they are over charging.
  7. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    He said door locks . That may mean they change the locks on the tractor doors and charge for labor installing them . That's the only way it would make sense (but not really ). If they were worried about former drivers getting in trucks they could swap locks on tractors that recently lost drivers .
  8. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    If they want me to use their special locks, they better provide them free of charge.
    walleye Thanks this.
  9. Gonzo_
    Gonzo_ Medium Load Member
    307
    143
    Oct 30, 2008
    Clayton, NC
    Lots of companies require things like "meat locks" and king pin locks.. If you buy them then you are more liable to take care of them, not loose the key and have to have someone cut it off the truck.. If $160 seems too high, try and see for yourself what kind of lock they require and buy your own?? I bet that is reasonable.. Those master locks 3 for $12 I bet arn't the locks they are talking about.. It sounds like a case hardened meat lock, they run about $90 - $125.. They wrap around both door rods.. The king pin lock.. depends.. some are aluminum, others are steel..
  10. WiseOne
    WiseOne Inactive contact bullhaulerswife
    2,613
    1,221
    Feb 8, 2004
    Truckers Report, TN
    Yes, it is much more so after 9-11. Before 9-11 only some did that, now almost ALL do that. I worked for Heartland for over 3 years and they would FIRE you for dropping your trailer, didn't matter about a lock. And, I mean dropping it to eat, go home, etc., not at a company, of course. So, YOU take the cost, these billions dollar companies don't have the money to pay for locks, you know!
  11. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    Granted, your description could be. But I still stand where I am.
    I have seen companies that require a lock on the door. I know drivers have bought their 30.00 lock and found that it was no more than a master lock.
    The problem with these deals is that when you leave they do not buy back the locks but expect them returned.
