buying used truck advice please help!
Discussion in 'Ask An Owner Operator' started by Mrnice81, Feb 19, 2015.
  1. Mrnice81
    Mrnice81 Bobtail Member
    28
    6
    Jan 1, 2014
    Pa intrastate
    I'm looking at a 2004 freightliner columbia automatic smart shift tandem axle
    Detroit 60 s 14.0L
    The vin number on driver door jam is ripped off
    All serial numbers stickers on engine are also missing
    plus aren't detroit 14L whistle screams like hell?
    This one wasn't screaming like it should. I'm guessing the turbo is shot?
    I test drove it and didn't hear a turbo whistle, this is my first time driving an automatic.
    Waiting on papers from rebuilt engine and tranny. That's why I consider the automatic plus it's price tag is 12000.
    Does this deal seem shady?
    Please help
  3. Mrnice81
    28
    6
    Jan 1, 2014
    Pa intrastate
    Also Jake brakes isn't loud, but I do feel it working .. is this normal
  4. Mrnice81
    28
    6
    Jan 1, 2014
    Pa intrastate
    Is there any other places where I can find a vin number to match the title?
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    With no VIN's anywhere to be found, and no serial # on the engine, I don't think I'd be buying it no matter how good of a deal it appeared to be. Without being able to identify the vehicle, you can't verify that the title you are getting belongs to that truck, and that really complicates things in the long run if it IS a different truck. Worst case scenario? It is stolen...which would be my luck. Mack stamps the VIN on the frame rail...up by the steer tire, if I remember correctly, on the right side of the truck. I would imagine other truck manufacturers also would stamp the VIN on a more permanent piece as well. If you can find that and it matches up, it is less shady than if that, too, is removed. If the VIN has been ground off the frame, I'd have my doubts as to the legitimacy of the title and the seller's claim to rightful ownership of the truck...
    RERM and Mrnice81 Thank this.
  6. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    I wouldn't do it, no VIN's .....seems shady to me..
    flood and Mrnice81 Thank this.
  7. Mrnice81
    28
    6
    Jan 1, 2014
    Pa intrastate
    thank you for your reply.
    I will call freightliner to see if I can find vin number elsewhere on truck.
  8. 062
    062 Road Train Member
    6,222
    33,477
    Oct 20, 2013
    Inside glove box,should have vin,trans and rear info.
    Mrnice81 Thanks this.
  9. Peterbiltt
    Peterbiltt Light Load Member
    236
    88
    Aug 21, 2014
    Ontario Canada
    im pretty sure you can find another deal like this WITH vin's so i wouldnt go for it
  10. fortycalglock
    fortycalglock Road Train Member
    6,155
    6,584
    Jun 25, 2011
    Tourist Town, FL
    VIN should be stamped in frame. Engine serial number is stamped in the middle of the block on driver side. It will start with 06xxxxxx.
  11. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    I'd run like hell. I would NOT buy that truck
