I have an 05 pete with the BXS Acert engine factory set at 550. It is showing trouble code 13. Can anyone tell me what that is?
BXS Acert engine code 13
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TA63, Nov 23, 2010.
Not sure but I think it's somthing to do with fuel temp
Unless you have a factory alarm -
I think thats for the fuel temp. Do you have a fuel wire on it? If so that may be the problem. If not maybe its unplugged or its bad.
Dont have a fuel wire yet. I unplugged my harness to try to install one, but it didn't fit. Maybe I have a bad connection now.
fuel temperature sensor is the correct answer.
If you have a fuel temp wire on it, either the resistor is bad or your wiring harness between the sensor and ECM is the problem
