BXS oil in coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Don2WS, Jul 9, 2011.
  1. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    2005 t200 witn the c15 acert my driver started seeing oil in the reservoir tank, i thought oil cooler removed it and tested it both boiling water and cold and switched the plates and nothing no leaks. this leaves off the water pump which was replaced in april 2010, air compressor, or liner. On my way home i started thinking how does the pre cooler work on these that might be the problem but my driver had the 1" hose from the reservoir to the cooler blow up and had to drive from iowa 80 to milwaukee with water in the cooling system so that might have pitted the liners so bad that they might push coolant back through the liner and into the oil when its the truck is shut off and once the truck is running the pistons will push oil through the sleeves idk maybe im just having crazy thoughts :biggrin_25524: the truck is about 8000 miles shy of a million i want to get it fixed and go trade it in and get my driver a 379 or a w9
  3. Tightwad
    Tightwad Light Load Member
    69
    16
    Jul 2, 2011
    I dont think that number of miles would have done it. It took three 400 mile turns with straight water and detergent to get all the diesel fuel out of my cooling system after my injector tubes went bad. Scared me to death but the shop just laughed at me when I said I was worried about liner pitting in that few miles.
    Don2WS Thanks this.
  4. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    When I had oil coming out the coolant rez over flow hose it turned out to be a bad oil cooler.....I'm no trained wrench just passing along what the big boss man said the problem was..
    good luck..
    Don2WS Thanks this.
  5. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Well the precooler has no oil involved in it...just pressurized intake air and coolant. Also running the truck that far won't cause enough pitting to even worry about. Now if the motor overheated than I would be worried. CAT engines can crack heads very quickly (even with water temps as low as 180* since all it takes is a air pocket). Make sure the oil cooler was tested correctly, then move onto testing the other thing. I would also pull a oil sample and look for high copper levels which would point towards the oil cooler.
    Don2WS Thanks this.
  6. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    Does that truck have a water cooled transmission? Could be the transmission cooler going bad. I had that happen to me and I replaced it with an air cooler.
    RoadRanger^^ and Don2WS Thank this.
  7. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    Don: I have had oil coolers test bad by soaking in boiling water and lightly tapping the cooler on the plate end, therby simulating road vibration. If the engine has never been down themn I would suspect liner being cavitated about half way up the liner where the compression can push the oil into the cooling system. If you do have a transmission cooler you can pull it off and pressure test it also. If you aren't running it hard for a trip or two bypass the trans cooler and see if anything. I have had one bad in all of the CATS I worked on.
    Don2WS Thanks this.
  8. Don2WS
    306
    26
    Feb 26, 2010
    Sturtevant WI
    Thanks guys. I'm away from the shop because I needed to apply the epoxy coating in the basement. But first thing tomorrow I'll throw some water in the microwave and fill the fish tank with the hot water and test it again. The tranny is air cooled. If the. Cooler tests fine ill remove the pan and add presuure to the cooling and see if a bad liner is the problem. But most likely I won'tbe having the pleasure to do the inframe on this truck. Because with the dry van rates out of wisconsin I've been getting these past weeks I'm thinking. That I seriously need to board another ship and go get myself a reefer or a stepdeck because $2200 from. Chicago to dallas isn't getting me nowhere but anyway thanks for all the help guys
  9. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
    did this truck ever get fixed i have a bxs cat doing the same thing and its not the oil cooler had 3 on it i just dont understand how a liner can put oil in water
  10. bavarian
    bavarian Heavy Load Member
    729
    782
    Feb 13, 2014
    Winnipeg
    Had the same thing going on on my c13. When I checked with CAT they told me rule of thumb is 20000 hrs. If you're over and have those symptoms it's quite likely that your liners show some cavitation and leak oil into coolant. I got my inframe done at about 27000 hrs.
    Not only miles cause wear, idling is the next big factor in this game.
    Make sure it's oil. It could also be fuel. But fuel I'd guess would smell out of the reservoir. The mechanic at CAT only put his nose in the reservoir and confirmed it was oil in my case.
    The next problem you're going to have is coolant hoses. You mentioned it already and it won't be the last one. Oil penetrates the silicone and damages the hoses permanently. Your hoses quite likely look wet and greasy now. That's oil coming out of the hoses. Hoses which are exposed to extreme heat are the ones which blow up first.
    I think it's time for an inframe and don't forget to replace ALL coolant lines after oil is removed from cooling system.
    If you do it yourself use dishwasher soap to flush the system. It doesn't foam.
    Good luck.
  11. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
