C-13 Head Gasket Job
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lonestar, Sep 19, 2013.
  1. Lonestar
    Lonestar Bobtail Member
    30
    May 17, 2008
    Totonto Onatario
    We are about to get the Head Gasket changed in a 2004 KCB C-13....
    What else should they check/replace/adjust while the head is off.
    I have heard the Injector tube O rings for one...
    Thanks
  3. gerardo1961
    gerardo1961 Road Train Member
    1,737
    600
    Feb 21, 2010
    Miami
    My c13 is a2006 Kcb,i spend $850 for the labor ,after the head was in the shop the change, the ,o-rings and sleeves from the injectors and new thermostats
  4. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    Have them check for bad head bolts. If any of them have erosion starting have them replaced. CAT had a problem with the back head bolts stretching as well. The other thing is to look at the cylinder that the head gasket was leaking at and ensure the liner protrusion is correct.
  5. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    CAT say's not to reuse head bolts for the c13 get new ones same goes for injector hold down bolts, check the liner protrusion and deck flatness.
