2007 NXS, 530k
Twice in last couple of weeks, it has thrown code # 55 (checking using cruise control). Don't know if it means anything, but both times this happened when taking off after ten hour break, during which engine ran @ fast idle, (which is usual). Can't say I noticed the first time, but second time the yellow cel was flashing, it de-rated engine for a short while- when it stopped flashing, engine returned to normal.
I had printed out a set of code #s some one had posted long time back, but can't put my hands on them; also seem to think they were for single turbo Cats. Is same code #s also good for Accerts?
Would appreciate if:
Someone could direct me to the post showing the code #s, and/or tell me what #55 is.
Thanks in advance!
C 15 Accert throwing a code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by droy, May 24, 2013.
55 I thought meant no codes all clear. but I have been wrong before. maybe a short for a second but not long enough to store the fault code.droy Thanks this.
55 means everything is good at the time you check it.
droy Thanks this. -
So everything is good, and it derates the engine just to be funny?
Or does it think you want to check for codes and slows ECM functions while checking?droy Thanks this. -
Just looked in my book to be sure. 55 is no codes found. Not to say u don't have a problem. Its just not throwing a code.
droy Thanks this. -
Next time it does it and the light is blinking you need to take a snapshot to get the ecm to log it. If I remember correctly you just hold the resume switch down for about 5 seconds and it will log it.
droy Thanks this. -
check the sensor for low water. it will derate it but not throw a code. if it derates again with no code just unplug the the harness from low water sensor and it will run just fine until you get a new one.
droy Thanks this. -
To trigger a snapshot, you need to make sure the cruise control switch is in the off position, then hit resume, immediately followed by set *or* hit set, immediately followed by resume. Either sequence will work. The snapshot will contain all the operating data for the 30 seconds prior to, and the 10 seconds after triggering the snapshot. A total of 4 snapshots can be stored in the ECM. The most recent of the 4 will overwrite the oldest if more than 4 snapshots are triggered.droy Thanks this.
Great info. I have always wondered how to do this.
Water level was visible in the sight glass, but on the low side. I added antifreeze to cover the sight glass yesterday when checking for causes, cel did not reappear. If it does it again, will try the snapshot.
Thanks for all the replies/help!
