C - 15 Acert Delete
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cap - 007, Jun 1, 2016.
  1. cap - 007
    cap - 007 Bobtail Member
    Hi, Guys.
    We had someone do a delete on one of our trucks. He also took of the twin turbo a put back on a single. After he got it done it all ran fine for about 15,000 miles. Now we have 2 codes showing up and 2 gauges stop working when the codes come on. Whenever it happens the oil and manifold pressure gauges stop working and the codes that show up are "Particulate Trap 1 Pressure and CGI Absolute Pressure."
    Starting the truck and even running it at times everything works perfect, but at times out of the blue they start turning up.
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    You would probably get more response at thedieselgarage.com
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    It's too bad you lost the twin turbos. They are not the problem, it's only the tuning.
  5. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Acert compression ratio + single turbo = blown head gasket/ cracked head to come.
    ####ing rookie delete shops have no business doing these things when they don't even understand how these engines run.
