C-15 Acert Low Oil Pressure.
Discussion in 'Freightliner Forum' started by desertdog71, Feb 24, 2012.
  1. desertdog71
    desertdog71 Light Load Member
    53
    14
    May 24, 2010
    Independence, KS
    I have a 2006 Columbia with C15 Acert. Last night when I shut down, I noticed the idle oil pressure was unusually high (55psi). I did not think much of it, but today when I started up the oil pressure would not come up at all, it was zero. I checked the oil level and I am full. Only about 10K Miles on the oil. Since the oil level was fine I went ahead and drove the last 3 hours. There is no loss of performance or noises to make me think its a mechanical problem. Also there is no warning lights or engine protect shutdown occurring with the zero pressure at idle.
    I suspect that it may be the gauge that is faulty, is there something else that I might consider before getting soaked by a shop?
  3. desertdog71
    53
    14
    May 24, 2010
    Independence, KS
    just to add to the above. Oil pressure never comes up above 25 psi under a load.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    i would say the guage is bad but i wouldnt run it until you find out for sure. a guage is alot cheaper to replace than an engine!
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    if is columbia. Oil pressure gauge is the electrinic immitation of gauge, really dashboard use J1939 data, so really oil pressure sensor is on engine. your engine ECM has protection program and if pressure is really low engine stalls.
    so I sugest internal dashboard issues related with corrosion ore dust it gauge stepper motor. Unfortunaly it is soldered in dashbourd and you cant swap it easily like with century class
  6. JDP
    JDP Medium Load Member
    377
    404
    Sep 25, 2011
    Dubuque, IA
    I've had the same issue on 3 or 4 of my C-13 Acerts. The issue on my trucks was the oil pressure sensor on the engine. These engines are in Peterbilt 386s but it sounds like the same issue. It was not throwing any codes on the dash. It usually happens when it's below 20 degrees outside.
  7. JDP
    377
    404
    Sep 25, 2011
    Dubuque, IA
    I've had the same issue on 3 or 4 of my C-13 Acerts. The issue on my trucks was the oil pressure sensor on the engine. These engines are in Peterbilt 386s but it sounds like the same issue. It was not throwing any codes on the dash. It usually happens when it's below 20 degrees outside. The sensor is a pain, at least on the EPA 07 Acert, it's right behind the fuel filter... PITA!
    Sorry for the double post, must have hit the button twice.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    BTW. What oil do you use? mineral ore syntetic?
