C-15 can it run on synthetic oil?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by doominik, Sep 16, 2013.
  1. doominik
    doominik Bobtail Member
    Sep 15, 2013
    Hi All
    My name is Dominik and this is my first post on this forum as I have only just arrived to America (only 2 weeks but have been driving 6 years in Europe) so HELLO everybody.
    My employer has bought me a lovely peterbilt 379 made in 2006 with cat c15 engine and it has been running on rotella 15W40 oil.
    We are looking for information if that engine can run on a synthetic oils such as 5W40. It would be handy as I will regularly drive it to North Alberta.
    Full Pull Florida and Oxbow Thank this.
  3. Cat sdp
    Cat sdp . .
    20,837
    71,796
    Apr 8, 2012
    Orion's Belt
    I've run T-6 Rotella 5w-40 in my C-15 for 5 years , no problems.....
    ps welcome....
    Oxbow Thanks this.
  4. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    If you are considering synthetic, I would recommend Schaeffer 9000 5w40 full synthetic. A very high quality oil. And I can get it for less than $20 a gallon when I get a drum of it, it is delivered FREE to my home, and they also throw in free oil sample kits with it. All you have to order is $300 worth to get in on the free shipping thing. Even if you ordered in smaller quantities than a 55 drum like I do, a couple of oil changes worth of oil will take you over the $300 threshold for free shipping. If you take a look at oil samples results that get posted at the BITOG website, you will find that Schaeffer really shines. The 9000 5w40 has a pour point of -42F, so it would work quite well for your cold country running.
    www.schaefferoil.com
    JPenn Thanks this.
  5. doominik
    Sep 15, 2013
    so we will get a 5W40 oil for it.
    Thank You
  6. Computertrucker
    Computertrucker Light Load Member
    80
    25
    Sep 7, 2013
    Umm I would recommend against making the switch if that engine has alot of miles on it. If you do your most likely going to be leaking oil all over the place.
    Leopard Thanks this.
  7. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Only because the synthetic oil ill clean out the inside of the engine. Sometimes the only thing keeping the engine from leaking oil is all the crud that has built up.......and the engine was running Rotella ;)
    Leopard and luvtotruck Thank this.
  8. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Right. Synthetic will not create leaks. It will expose leaks that would have been there already if the engine wasn't so crudded up with sludge and goop around the seals. Synthetics usually have a very robust additive package that will tend to clean out deposits. If the engine was well taken care of, and is clean inside, then synthetic will not change a thing and the old wive's tale about synthetics will remain that....an old wive's tale.
    603tmac Thanks this.
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    well find me a 2006 running regular oil that is "clean"
    so creating leaks or exposing leaks is semantics
    just another old wife
  10. mkmac
    mkmac Light Load Member
    77
    17
    Sep 29, 2013
    Langley B.C.
    In all my research Schaeffer is the only company that I have found that sells a true synthetic that is not blended with group 3 oils. Some people that use amsoil think it's a pure synthetic but its only a blend of cheaper mineral base oils with synthetic additives it's okay if you change you oil regularly but not for long term changes with a bypass filter, I just find it weird how with the internet people don't do a little research..............Just saying..
    Jokingypsy Thanks this.
