C 15 cat running a little rough
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Steve62, May 17, 2016.
  1. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    so when I am running the mountains, going up hill down shifting down all is good up shift and the engine seems to flutter. Put it to the floor it flutters or misses for 5-10 seconds then clears and pulls fine. No codes. I am thinking I have a weak fuel injector.
    Any ideas???
    Thanks Steve
  3. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    How long has it been doing this? If it just started try changing fuel filter first.
    If it has been going on a while I would change engine speed sensor first, since it isn't throwing a code.
    Steve62 and justa_driver Thank this.
  4. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    I had a flutter on my E model but it would throw a code . It was the wiring hardness.
    There would be days that mine would purr smoothly and there will be days it would run a little bit rough, but would be the same mpg. It wouldn't miss, just idle a little rough. I guess it has its good and bad days.......
  5. cat2d
    cat2d Bobtail Member
    5
    Apr 30, 2016
    Sounds like a crook injector. Getting on and off the gas or splitting gears de-energizes and energizes the solenoids and if one of these are slow to re-energize it will cause a missfire/shudder under load until the solenoid comes back to life. Not sure how long the fault has to be in it for the ecm to log a code.
    mc8541ss Thanks this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Change fuel filters and see if it cures it. If not check fuel pressure may be a weak check valve or transfer pump or primer pump may be bad. If that don't cure it then I would run an injector cutout test to see if you have a weak injector. Little cheap things first before you start throwing big $$$ at it.
  7. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    I used to change the fuel filters on my cat about every 10,000 miles.
    Kw Owners Club Thanks this.
  8. mc8541ss
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    Mine gets changed at 12k when I change the oil. Before I had NASTC fuel card and I was filling up where I could find the cheapest fuel instead of the bigger truck stops, I would have to change fuel filters before truck was due for oil change.
  9. Steve62
    170
    98
    Mar 5, 2015
    Northern BC
    Took her in, turns out there is a twisted pair of wires that run from the ECU to the speed sensor. The shop could not even run the diagnostic program until they replaced the wiring. Everything checked out ok. Seems to be running better, won't really know till I run her through the canyon.
    Thanks for your input.
    Steve
    Oxbow Thanks this.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    After eliminating the filters as the problem i'd check your return fuel pressure. what you describe is what happened when the fuel transfer pump started going bad on both of our BXS engines and a 5EK.
  11. Steve62
    170
    98
    Mar 5, 2015
    Northern BC
    So just put another 4K on her. Still not running right, but at least now she through a code. 94 intake actuater valve. Low or high voltage. Number 5-6 cyl.
