C 15 engine noise
Discussion in 'Kenworth Forum' started by Bzim, Jan 10, 2014.
  1. Bzim
    Bzim Bobtail Member
    I have a 2007 c15 with a very annoying noise. Low pitched drone most noticeable under load between 1300-1400 rpm. Been over the exhaust multiple times, replaced engine and can mounts, checked everything else I can think of. Seems to be a fine vibration, but can't find the source. Suggestions?
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Silly question, has anyone ever flushed the power steering system and changed the filter in the reservoir?. Power steering pump starving for oil. Will cause cavitation and a whinning noise at higher rpm's.
  4. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    <edit/disregard> apparently jason is replying to your thread
  5. 07shaker
    07shaker Light Load Member
    189
    626
    Jan 12, 2013
    Tx
    What model truck is it? A friend of mine has a 2002 379 and he had some kind of noise that several people looked for and couldnt find. Ended up being the cab mounts were shot. I have no idea if its the same for yours but it could be something to check.
  6. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Another thought, how many mi on trk?. Have you checked vibration damper on crank?. They do go bad and will cause torsional vibrations in the crank, if bad enough the vibrations can cause crank failure. Especially under a load.
  7. Bzim
    Bzim Bobtail Member
    How do I check vibration damper? Can I pull it off and run it; see if it makes a difference?
  8. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I've always replaced them at about 500k. Only way i know is to take it off and put on a known good one. My no means do you want to run that engine with out the vibration damper. The harmonics from the firing of the cyl's will desroy the bearings or the crank in short order.
    Have you checked the isolator bushings and rubber exhaust part hangers. If the rubber is torn and the exhaust parts are rubbing metal to metal will set up a vibration through out the chassis. With out being there personally i'm just guessing. Hope it helps
