C-15 not giving full boost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Migreig, Mar 24, 2016.
  1. Migreig
    Migreig Bobtail Member
    9
    Hello everybody,
    I have an issue with my '07 T800 with the twin turbo C15. Every morning when I fire the thing up, it will only give me just over 30lbs of boost. This goes on for 15-20 minutes. Usually when I'm midway up a big hill it kicks in and goes up to 49lbs of boost. After that it's fine for the rest of the day.
    I haul heavy equipment in a hilly area so you can imagine how annoying this is with a 49 ton excavator on!
    It never throws a code and I'm lost as to what the problem is. I've changed the boost pressure sensor on the advice of my Cat dealer to
    no avail.
    Any help you can offer is really appreciated!
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    What does your temp gauge show? I just dealt with similar situation with a bad connection on the coolant temp sensor. All the usual checks found nothing. No codes, but when taking it for a ride, I noticed it had a status flag for "cold run mode" and the temp gauge was below 100. It was stalling around 30 psi of boost. With a infrared temp gun it was really 190 at the T-stat housing. New sensor and harness end got the temp gauge working and we were able to get 40 psi on a small grade empty. Driver says it's back up to 45-50 loaded now.
    wore out Thanks this.
  4. Migreig
    9
    It won't give me full boost in the morning until it's at least 150°f.
    Sometimes it's as high as 180°f. Once it kicks in, it's good for the day, regardless of temperature.
  5. Migreig
    9
    Of course right after I said that it dropped off for ten minutes in the middle of the day....
  6. Migreig
    9
    How do I check a status flag?
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    You need a laptop with Cat ET for that. I'm not saying that it's your issue, it's just a similar issue that I ran into for the 1st time recently that made me scratch my head for a bit. It should not be in cold mode at 150*, so I'd look elsewhere.
    May not be an option for you, but my next step would be to have someone else drive while I use Cat ET to monitor all sensors and look for something out of the ordinary. Then I'd run the injector and intake actuator tests. It'll be a process of elimination starting with the easiest things first.
  8. Migreig
    9
    "It should not be in cold mode at 150*, so I'd look elsewhere"
    If there was a bad connection at the coolant temp sensor or a bad sensor could it not cause that?
  9. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    On your truck, the temp gauge runs off the data link, so the ECM and the gauge are getting the signal from the same sensor. If you suspect that the gauge is not accurate, then look into it. But if the gauge is accurately reading 150* , the ECM is seeing 150* as well.
    In my case, the gauge was bottomed out below 100* at all times (the ECM showed 75* on Cat ET), even though the engine was 190*.
  10. vasili333
    vasili333 Bobtail Member
    17
    Sep 4, 2013
    I've got same thing in the morning turbo wont spool and after I hit 150 degrees and above it will break loose. I was told its a cold mode.
    Migreig Thanks this.
  11. Migreig
    9
    Exactly my symptoms...never experienced this on any other truck.
