c-15 problems
Discussion in 'Peterbilt Forum' started by honsolow, Oct 3, 2014.
  1. honsolow
    honsolow Bobtail Member
    i just did an in frame on my c 15 cat. went about 600 miles and it jumped time thought i may have torqued the front end wrong so i redid it had the head redone new valves replaced and the engine only went 250 miles this time any ideas out there?
  3. SL3406
    SL3406 Medium Load Member
    550
    1,491
    Jan 10, 2011
    Oklahoma
    Are you using the cat tool to set the backlash? How is it jumping time? Stripping the gear teeth, or is the idler gear adjustment slipping from where you set it?
  4. honsolow
    yes on the cat tool its not stripping the gear teeth the idler gear is'nt slipping when it slips time it shears off the gear for the cam shaft.
  5. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Are you sure the cam turns freely, and it's not binding causing the gear to shear off?
  6. aplustrucking
    aplustrucking Bobtail Member
    31
    Nov 19, 2014
    Sayre, Oklahoma
    It sounds like you didn't get the bolts tight that hold idler gear in place causing it to back away resulting in excessive gear lash. This is the first time I've heard of a c15 jumping time and I've worked on and overhauled my fair share. Have you pulled the front off of the motor too look for other missing or broken teeth?
  7. dinitranport
    dinitranport Bobtail Member
    hi im new to the forum i need help with this poping up sid 32 fmi 07 not check engine light on any help would appreciate
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    dang impossible to (jump) timing unless you shear teeth off gear. if it has done twice then something wasn't done right. did it bend valves? check the counter weights in cam gear and inspect cam gear assembly for wear and cracks. if you have lash gear set to tight it will fail after the engine heats up. must dial indicator it for the lash. using the cat tool is not enough.check the spacer ring that goes between the cam and cam gear. make sure it was installed correctly. did the cam walk forward and hit the cover?
