C-15 Vibration
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by awright, Nov 4, 2017.
  1. awright
    awright Light Load Member
    86
    16
    Dec 20, 2016
    I have finally replaced the last four fuel injectors, and still have a vibration under load, and a rough idle. I have a 2007 C-15 acert 625hp with single turbo. Anyone have any thoughts?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,531
    6,594
    Aug 26, 2014
    Search block on top right. Enter C 15 vibration. I recently saw one similar to that. It had a wire with insulation worn through and shorting. It was at rear of engine but for the camshaft sensor.
    SAR Thanks this.
  4. awright
    86
    16
    Dec 20, 2016
    will check it out thanks
  5. truck 307
    truck 307 Light Load Member
    179
    315
    Aug 11, 2014
    are you 100% sure its a engine mechanical issue ? Im thinking more along the lines of electrical. Have you cleaned up the primary ECM power feed inside the left frame rail beside your left steer tire ? Have you checked all 3 power feeds to the ECM ? One will be from your fuse box, a second from that frame mounted 120 amp power junction / supply, and the 3rd directly from your batteries (in battery box )
