C-15 weak jake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by T2416, Dec 3, 2008.
  1. T2416
    T2416 Bobtail Member
    5
    Laramie, WY
    Ok, is there anything that can be done to get decent jake brake perfomance out of the cat motors, that even compares to the ISX? :biggrin_255: I was reading the jakebrake FAQ the other night, and they state it's not advisable to try and up the manifold pressure... my question is, why is there such a disparity between manifold pressure seen on the ISX's vs the cat engines? For that matter, why are the jake brakes on the cats so weak in comparison to the ISX engines?
    I'm dropping 6-7 miles of 7% every day... I'd really like to get it done faster, w/o smoking the brakes or having to crawl down it in 10th (18 speed).
  3. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    Need your engine serial number to give you more information, have you had the top-end set?
  4. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    They probably need to be set, i found the 3406E and C15/16 brake better than any cummins i ever drove.
    I noticed i lost some braking with my big turbine housing and B manifold but not enough to not out brake any N14 or ISX i know of. Have a friend with a ISX that complains of the same thing as you.
  5. CaterpillarWrench
    CaterpillarWrench Light Load Member
    188
    49
    Nov 11, 2008
    Wrenching feverishly
  6. T2416
    5
    Laramie, WY
    Done. Supposedly. Cat dealer in Cheyenne. Was in for new injectors about 2 1/2 months ago, then back in about a week ago when the jake went on the fritz. I let them know the jake performance was lacking, but they didn't have much to offer for an answer.
    MFG date on the truck is 08/03. Set at 525. MBN- everyone's fav. With 3.90 gears, btw. I have yet to drive a cat that comes close to any ISX I've driven, as far as jake performance goes. Seriously. The ISX guys are blowing my doors off down the hills. I'm beginning to miss the red motor, but it's not my choice to make. Might not matter much once the snow and ice become a daily PITA, but that won't last forever.
    I can probably have someone else check the top end, but I'm wondering what other avenues exist... it really is lack-luster.
  7. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    I drove a C-15 in a KW while mine was in the shop 3 weeks ago and the jakes on that were weak they made all the right sounds but just weak.
    Over here CAT jakes arent even on the same page as ISX jakes thats why I have a brakesaver as well combined with jakes they will blow away a ISX easy down hill.
  8. DDS
    519
    177
    May 20, 2008
    Toronto
    then back in about a week ago when the jake went on the fritz\
    Has the jake power changed since you owned it??? I need a engine serial number to check to see if you have jake brake or pac brake. If is a pac brake, you may have a cracked housing or worn slave bores. The jake brakes can also move resulting the settings going out.
  9. WallyGator
    WallyGator Medium Load Member
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    I have the same problem with my 3406E ser#5ek39064 lots of sound but not much more. my 60series was 10times better at slowing you down but not much noise:biggrin_2554:
  10. Truck Driver
    Truck Driver Medium Load Member
    330
    136
    Dec 5, 2007
    Sacramento, CA
    The jake on the 430, series 60 detroit i'm driving is deafining but dosen't slow the truck even bobtail while the jake on the 365, 3176 cat i drove could lock up the drives and was barely audiable in comparison.
  11. rockrawlin
    rockrawlin Bobtail Member
    47
    20
    Sep 5, 2008
    Chico, CA
    I love the Jake in my 1LW Cat. I can come down a 6% grade fully loaded at 55mph and never touch the brakes. It builds upwards of 24-25 psi manifold pressure.
    Not even in the same ballpark as the old Series 60 or Cummins.
