C-16 Dyno
Discussion in 'Trucks [ Eighteen Wheelers ]' started by C16KIWI, Nov 20, 2008.
  1. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    This is for the people that have helped with some of the problems I have had and whoever is interested.
    Just had my truck dynoed to make sure everthing is where it is ment to be
    The engine was returned back to stock settings this is how it went:
    2004 C-16 flash/f no:2707125 FLS 44 FTS -77
    Wheel HP:583hp
    Engine HP:648hp
    At 1600rpm
    The only thing low was the boost about 30psi so it shows low boost doesn't all ways mean low HP bit it will efect responce.
    Because everything was in spec they would not change any settings to try and improve anything.
    As far as high EGTs we did one run with there probe in the cool side of the turbo and then one run with the truck probe in:
    The highest the dyno pyro got was 1062*F
    The truck pyro probe was 1300*F
    So I would think that the truck probe could be out a little bit also if the boost was up around 33psi the EGTs would be lower still and HP up maybe.
    There is 7 pages of this dyno so anyone wanting to know more ask away.
  3. CaterpillarWrench
    CaterpillarWrench Light Load Member
    188
    49
    Nov 11, 2008
    Wrenching feverishly
    Not bad for a C16.Too bad you don't have somebody to push that -77 up to around zero,might cool your egt's down a little. But according to the dyno probe,your ok there too.
  4. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    I think we talked before about the gauge in problem. I have a western star that I had on the dyno for high exhaust temperature last Tuesday. I hooked up a Autometer pyro to confirm dash pyro, I found that the truck was 200 higher than the autometer. Customer complaint of 1200 during a pull. I have the proper pyro ordered from western star. It has a k type probe right now but w/s look up for the truck by serial number is different. W/S also has a small air to air cooler ( compaired to Peterbilt) You could measure the pressure drop across the cooler. It may be the turbo is working to hard trying to push high boost through that air to air. there is a test port on the outlet elbow of the cold side of the turbo.
    I got your email with dyno result. Your fuel is over spec at 1200 and 1400 but should not be an issue. Boost is a little low for the fuel flow. It is to bad that they did not put 0/0 in to see the difference. Do you have 5232 or are they stock injector numbers? I will be posting results of a back to back dyno run on a mbn to 6nz flash file change soon, just to busy at work right now to get it on here.
  5. C16KIWI
    575
    142
    Jun 14, 2008
    New Zealand
    The injectors are running on the stock numbers,they had taken boost readings on the elbow of the turbo and from the inlet manifold to see how much drop it had through the aftercooler it was in spec but a little high.
    Already have been looking at aftercoolers we can get Dura-Lite coolers here so might look at that.
    Brought a new probe yesterday might fix the problem.
  6. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Dyno looks perfect, thats a strong stock C-16 Shaun.
  7. garypeterbilt
    garypeterbilt Bobtail Member
    47
    7
    Nov 19, 2008
    Seymour, Texas
    Do you know where i can get a 7CZ computer for my MBN and anything else to make it run ?
  8. DDS
    519
    177
    May 20, 2008
    Toronto
    You can get any used 70 pin ecm from a c15 and it can be flashed to a 7CZ. Its easier than trying to find a 7CZ ecm.
  9. CaterpillarWrench
    188
    49
    Nov 11, 2008
    Get somebody to change your injector codes to 5232.MBN responds very well to that.But then you still have a $##%$ mbn.Also some MBN have trim files,never saw any with em though,but if you have a 4 digit number for the injector calibration and change that to 5232 your good to go.
  10. DDS
    519
    177
    May 20, 2008
    Toronto
    I have also never seen a MBN with trim files, the injector part number seems to be the same for all MBN's. If the part number of the injector is the same for all, I do not see how they could have trim files?
    216-7225 PUMP GP-FUEL INJECTION
    S/N MBN1-30210
  11. CaterpillarWrench
    188
    49
    Nov 11, 2008
    The trim file does the same thing as the code does,tells the ecm how long to keep the solenoid energized,and also that is how they get the multiple injections on an acert.I think Cat went to trim files to get away from 5232 codes,but I think I have found a way around that too.Never tried it yet though.There is also an early bxs that used that injection pump group.
