C12 Cat with bad camshaft and water in oil 70k miles on rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ballaholic29414, Sep 4, 2018.
  1. ballaholic29414
    ballaholic29414 Bobtail Member
    Charleston, SC
    I have 2002 Freightliner Columbia with a c12 catepillar with 70k miles on the overhaul I had done 2 years ago and I started hearing a ticking sound from my engine and got it checked and the #6 exhaust valve was loose so they tightened it up back to specs and told me If that sound comes back the camshaft is bad. Well the ticking came back 3 days later so I pulled it off the road until I could get another shop to look at it. I got it checked and found out I do have a bad camshaft by looking at it from the bottom end. But we also saw sludge like water and oil mixing coming from the exact same cylinder all of the other cylinders didn't show any signs of water and oil mixing at all. When I did the complete overhaul 70k miles ago I replace. Camshaft, head, cam followers that were bad(shop never informed me I should change all) I did a complete inframe also. Paid 13k now 2 years later I'm back with this problem and a water in oil issue. I really dont want to put anymore money into this truck I've owned it 3 years and this will be my 2nd time in the engine. I would sell it as is but it isn't worth anything like this so I will probably fix then drive it til I can sell it. Any ideas what's causing water to leaking in the same cylinder as my wipes lobe on my camshaft?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Shine light up and see if coolant is coming from outside of liner(o-ring) or inside of liner(leak @ head gasket). Head will have to come off regardless to replace cam followers. Head bolts are one time use on C-12. Also look over rockers well. Tend to pit over time @ fulcrum where they contact valve bridge. Reman ones don't hold up if you plan to keep truck.
    pushbroom and SAR Thank this.
  4. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    liner seals as its only a single seal on that.
    cracked liner
    cracked head
    damaged injector sleeve or sleeve seals
    cracked block
    damaged liner.
    head gasket
    if the cooling system doesn't pressurize with combustion gasses and the crankcase doesn't excessively breathe that will rule out injector sleeve, cracked liner or head gasket.
    if the head is cracked they tend to also pressurize the radiator but not always. check your dump pipe off the turbo, if there is white residue in it its possible a cracked head.
    otherwise leaves the probable options of damaged liner seal or cracked block.
  5. ballaholic29414
    Charleston, SC
    Update. I replaced the camshaft and all the rollers and sleeve oring and of course all the gaskets. Truck runs good. But after the 4th of work it sounds like the ticking sound is coming back mainly after the truck has warmed up pretty good. It seems like dejavu I am taking it back to the shop on Monday to get it checked out. It isnt as loud as it was of course but I can definitely hear something is off. The shop told me to bring the truck back in 1 month to get a overhead done on it. When they took the old cam out they told me they think the cam went out because the valves were adjusted too tight. My number 6 roller had a completely flat spot on it.
