c13 acert thermostat plz help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Jun 10, 2018.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    hey, i took all four bolts for my c13 acert thermostat housing to take off the thermostat, its loose but its being held in by some tube that runs down past the second turbo, do i take out that tube from the housing side or turbo side and how would i take it out
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Tube goes down to w/p. Tube is bypass when thermostat is not open. O-ring on both sides. Hold pipe with pliers and pry up with pry bar on t stat housing. Penetrating spray and twisting helps.
    wtokhi Thanks this.
  4. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Remove the clamp from the end away from the thermostat housing. I believe the end with the clamp on it goes to the oil cooler. I have a C15 and that is the way it is set up.
    wtokhi Thanks this.
  5. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    No clamps on a c13. Just keep prying and spraying wd40 or similiar, they are a pain to get apart but go together alot easier.
    wtokhi Thanks this.
  6. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    What they said. Been there. Done that. Thought I was going to break something. But didn't.
    wtokhi Thanks this.
