C13 oil capacity
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bdog, Aug 9, 2016.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I have a 2007 379 with a C13. Will be doing the first oil change on it myself tomorrow. Googling gives me some conflicting info on the oil capacity. Best I can tell is nine gallons. Anyone know if this is right?
  3. Animosus
    Animosus Heavy Load Member
    710
    2,798
    Dec 7, 2015
    SE Wyoming
    Til it's between the hash marks. Looks like about 10 gallons.
  4. bavarian
    bavarian Heavy Load Member
    729
    782
    Feb 13, 2014
    Winnipeg
    9 to 10 gallons.
    Prefill filter before installing, which takes almost a gallon already. Fill the rest in engine. Start her and let her build up oilpressure.
    Shut down and let her sit for ten minutes to allow the oil to drain down from the head into the oilpan. Change fuelfilters or lube the chassis in the meantime.
    Check the dipstick.
    Be prepared for 10 gallons.
  5. Bdog
    1,057
    877
    Nov 6, 2014
    Got it changed. I used a 1R-1808 oil filter which is what Cat gave me and it fit fine but was a few inches longer than the Cat one that came off there. I put in nine gallons as a start and let it run, then shut it off and let it sit fifteen minutes. It was right at the full mark maybe a 1/16" over actually. Greased her up, changed the fuel filter and ready to roll again.
  6. bavarian
    729
    782
    Feb 13, 2014
    Winnipeg
    The 1R-1808 is what CAT calls a high performance filter which might replace some others.
