c15 & 16
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dunctrk379, Jul 18, 2011.
  1. dunctrk379
    dunctrk379 Light Load Member
    213
    11
    Jul 12, 2011
    lowndesboro,al
    whats the difference in c15 block and c16 block? I was wanting to know if its possible to put c16 internals in c15 block when it comes time for rebuild?
  3. Far_Call
    Far_Call Medium Load Member
    453
    416
    Aug 21, 2009
    Australia
    Nothing as they are the same block.
  4. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    doesnt the c16 have problems with the aprons?
    why not just build the c15 with a hopped up ecm?
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    well, you can get reason5 pass and reflash ECM... but really there is a lot of difference! C16 and C15 are of really different parts lists
    Try to get C15 engine number, get Cat SiS and try to pring C15 and C16 parts lists to compare!
  6. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    The original question was whats the difference in c15 block and c16 block. So if blocks are same I think someone can put internals from one block to another even those internals may not be same.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yeah.. he can swap all internal stuff
  8. dunctrk379
    213
    11
    Jul 12, 2011
    lowndesboro,al
    Well thanks everybody for your help. The reason I ask is that its well know there is no replacement for displacement when all things are created equal in the smaller cubic inch and the bigger cubic inch which one will always over power the other, we all know the bigger one.
  9. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    Whew............you ain't priced the crankshaft yet. The parts will interchange between the blocks, but to buy them takes a small fortune
    Actually you'd be surprised how close the two engines are in Hp when you play with them. The larger cubic inch engine doesn't gain much advantage in Hp, but if you want to talk about the torque differences, the difference is big in a C-16
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    low end torque is a good thing, but driving engine at low speed with pedal to floor is not good for fuel milage and sometimes C16 drivers got less miles per galon comparing with C15, becouse they do not shift down in time
  11. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
