C15 6nz low oil pressure fault code
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6nz389, Mar 17, 2018.
  1. 6nz389
    6nz389 Light Load Member
    54
    45
    Nov 14, 2017
    Have 6nz with 450k on it and 10k hours, gauge says 70 psi cold and good n hot idle 700rpm 27-30psi, hot it runs 58-60psi at 1500 rpm. This all seems good to me but I'm getting an occasional check engine light for low oil pressure and had one that said extremely low oil pressure a couple weeks ago. Shop I use said it's probably just from cold starts as I don't have a engine oil heater and I'm up in ND. Does this sound right?
  3. Goodysnap
    Goodysnap Road Train Member
    3,701
    8,977
    Jul 12, 2017
    I would inspect the oil psi sensor at the body, they will usually start to leak and the sensor body comes loose. It may be failing electrically and glitching faster than it can report to the gauge, but the ecm picks it it up.
    Oxbow, spsauerland and 6nz389 Thank this.
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Is there one or two oil pressure sensors on your 6NZ? May be you have one for your gauge and another for ECM input...
  5. 6nz389
    54
    45
    Nov 14, 2017
  6. 6nz389
    54
    45
    Nov 14, 2017
    I will look tonight
  7. truck 307
    truck 307 Light Load Member
    178
    315
    Aug 11, 2014
    I have a 6NZ Cat in a 2003 pete 379x. I also have had that a few times, but CAT said they cleared the code and to advise them if it happens again, which it did. They next uploaded the latest updates (newer version) into my ECM and it never happened again.
  8. Diesel Dave
    8,594
    24,042
    Jan 20, 2010
    Hesperia, Ca.
    My oil pressure gauge gets stuck about at 5psi, it will read like at 60 psi when normal is about 65. I just tap on the gauge and it goes back to normal. I would get a Cat ET and see what it reads. Or just go the less expensive route and replace the gauge and sensors as said above.
